What’s a reliable alternative to Google Drive for everyday use?
I’ve been using Google Drive for years, but lately I’m running into storage limits, slow syncing, and worries about privacy and data control. I’d really appreciate recommendations for trustworthy Google Drive alternatives that work well for file backup, sharing, and collaboration across devices, and why you think they’re better options.
What I Ended Up Using Instead Of Google Drive (After Way Too Much Trial & Error)
So I hit the point where my Google Drive looked like the digital version of a hoarder’s basement. Stuff everywhere, duplicates, old docs from like 2014, random ZIP files I swear I’ve never seen before. On top of that, I started getting uncomfortable with shoving everything into one company’s cloud.
I didn’t quit Google overnight, but I started testing alternatives and mixing tools. Here’s what I actually tried, what stuck, and how I’ve been handling storage lately.
Why I Stopped Relying On Just Google Drive
Not going to pretend Google Drive is ‘bad.’ It’s not. It’s just… not great at everything:
  • Storage limit anxiety once you hit the free cap
  • Awkward if you use multiple clouds (Google + Dropbox + OneDrive, etc.)
  • Sync issues on macOS every now and then
  • Not ideal if you want more control over where your files really live
What finally pushed me was realizing I had important stuff spread across:
  • Google Drive (docs, sheets, random stuff)
  • Dropbox (shared client folders)
  • OneDrive (work account)
  • iCloud (Mac + iPhone backups, photos)
And I kept jumping between like 4 different apps to find a single file. Felt stupid.
The ‘Just Pick Another Cloud’ Phase
First thing I did, like most people, was try to replace Google Drive with another single service.
Dropbox
  • Sync is solid. Desktop integration is nice.
  • But pricing is not exactly generous if you’re casual.
  • Also, guess what: I still had stuff on Google, so now I had two silos.
OneDrive
  • Works fine if you’re deep in Microsoft world.
  • For me it basically turned into “the place where my work stuff auto-saves.”
iCloud Drive
  • Great on Apple devices.
  • Not amazing if you’re jumping to Windows or sharing with people who aren’t in the Apple ecosystem.
Result: I just ended up with more clouds, not less chaos.
The “What If I Just Use External Drives” Phase
I tried going old school: external SSDs, Time Machine, local backups.
  • Fast.
  • Private.
  • No monthly fee.
  • Not accessible when I’m away from my main machines.
  • You will forget to plug it in and back up for weeks.
  • One mistake (lost drive, damage, theft) and you’re in trouble if it’s your only copy.
So I still needed cloud storage. But I didn’t want everything sitting in one company’s servers anymore.
The Setup That Finally Worked: Multiple Clouds, One Frontend
What ended up working for me was not replacing Google Drive at all, but treating it as just one of several storage locations and using a tool to unify them.
On macOS, the app that made this tolerable for me is CloudMounter:
CloudMounter
I’m not hyping it; this is literally what I use now.
How I Use It
Instead of syncing everything locally, it mounts different cloud accounts as if they were external drives in Finder. So I can connect:
  • Google Drive
  • Dropbox
  • OneDrive
  • Amazon S3 / WebDAV stuff
  • Even some SFTP for a server I use
All of them show up like separate disks. Click, browse, open. No massive sync folders eating space.
So in practice:
  • My “active” work lives in a couple of folders that do sync locally.
  • Big archives live on different clouds, mounted through CloudMounter when I need them.
  • I can keep Google Drive for collaboration, but not depend on it for everything.
Concrete Alternatives I Actually Keep Around
If you’re trying to move away from heavy Google Drive dependence, here’s what’s been sustainable for me:
1. Dropbox + CloudMounter
  • Dropbox handles anything I share regularly with other people.
  • Through CloudMounter, it behaves like a drive I attach or detach when I want.
  • No need to sync the full monster folder to my Mac.
2. OneDrive For Work Docs
  • Work projects go on the work account.
  • I don’t mix personal and work anymore, which has saved me from accidentally dragging personal stuff into company space.
  • Also easily mountable in one place instead of another separate app window.
3. iCloud For “Apple Life Stuff”
  • Photos, screenshots, random personal docs, app data.
  • Mostly stays invisible and quiet.
  • Still accessible in Finder, but not something I lean on for multi-platform sharing.
4. Google Drive For Shared Docs Only
I stopped treating Google Drive as my “everything box” and downgraded it to:
  • Shared docs
  • Forms and Sheets I collaborate on
  • Temporary storage for stuff I’m sending around
The heavy lifting now sits across several services, brought together by a single file manager instead of 5 apps.
Why This Ended Up Better Than Swapping Services
Just picking “the next Google Drive” doesn’t fix the core issues if:
  • You still end up with multiple clouds anyway
  • You run into the same sync annoyances, just with a different logo
  • You want to mix personal, work, archival, and temp storage in different ways
I found it way more practical to:
  1. Keep multiple providers, each for specific roles.
  2. Use something on my Mac to glue them together. For me that happened to be CloudMounter, because it just mounts them like drives without needing full sync.
  3. Keep local backups for the really important stuff (external SSD + occasional offline copy).
If You’re Trying To Move Away From Google Drive Right Now
If I had to redo the whole process from scratch, I’d probably:
  1. Decide what actually needs to leave Google first.
    • Sensitive stuff? Big archives? Old backups?
  2. Pick at least 2 clouds, not 1.
    • Example: Dropbox for active shares, iCloud or OneDrive for “quiet storage.”
  3. Use a tool that lets you mount them all on macOS in one place.
    • In my case: CloudMounter.
    • Idea is: stop jumping between 4 different native apps just to find a PDF.
  4. Keep Google Drive, but demote it.
    • Treat it as one of several drives, not the center of your digital life.
That mix of multiple smaller clouds + one unified way to access them has been a lot less stressful than betting everything on yet another single “Drive alternative.”
If you specifically want “one thing instead of Google Drive,” I’m gonna slightly disagree with @mikeappsreviewer and actually name a few that can stand alone, depending on what you care about most.
You mentioned three pain points: storage limits, slow sync, and privacy / data control. Here’s how I’d match those.
1. Best overall Google Drive replacement: Dropbox
Not original, but still true:
  • Sync performance: Still the most reliable desktop sync in my experience. Large folders, lots of small files, versioning… it just works.
  • Everyday use: Native apps on every platform, file requests, good sharing links, comments.
  • Downsides: Pricing is not amazing if you’re super casual, and it’s not a privacy-focused provider. You’re basically swapping Google for another big SaaS.
Use this if: You mainly want something that feels like Drive but faster and less janky on sync.
2. Privacy-focused alternative: Sync.com or pCloud
These are what most privacy-conscious folks land on.
Sync.com:
  • End-to-end encrypted by default.
  • Zero-knowledge: they can’t read your files.
  • Good web app, decent desktop apps.
  • Sharing links, permissions, etc.
pCloud:
  • Very solid sync and backup features.
  • Lifetime plans sometimes make financial sense.
  • Encryption is a separate “Crypto” add-on, but well done.
Downsides:
  • Collaboration is not nearly as slick as Google Docs/Sheets.
  • Real-time doc editing through the browser is weaker or non existent.
Use this if: Privacy and data control beat “live collaboration” for you.
3. If you want control over where data lives: Self-hosted (Nextcloud)
This is the “I want to own my stuff” route.
  • You can host on a cheap VPS or even a NAS at home.
  • Features: cloud storage, calendar, contacts, even Docs-like editing with plugins.
  • Tons of apps and plugins.
But:
  • You have to maintain it. Updates, backups, security, etc.
  • Not for “I don’t want to think about it” personalities.
Use this if: You’re comfortable with some server admin or willing to learn.
4. Hybrid approach with CloudMounter
Where I agree with @mikeappsreviewer is that you don’t have to find “The One” service. What they described is basically a “multiple clouds, one interface” strategy.
CloudMounter is really good if:
  • You want to use Google Drive, Dropbox, maybe pCloud or OneDrive at the same time.
  • You don’t want everything syncing locally.
  • You like the idea of mounting clouds as drives in Finder instead of juggling 4 separate apps.
With CloudMounter, you can do:
  • Privacy stuff on Sync.com or pCloud.
  • Collab stuff still on Google Drive.
  • Work files on OneDrive.
    All appear as mounted drives. No need to download 500 GB locally.
This doesn’t fix Google’s privacy policy, but it does let you shrink what you keep on Google to just what really needs their Docs/Sheets magic.
5. If I had to pick one for everyday use
  • Want easy, no-brainer, good sync: Dropbox
  • Want privacy and you can live without live Google Docs editing: Sync.com
  • Want privacy + one-time-ish payment: pCloud
  • Want max control & don’t mind tinkering: Nextcloud
  • Want flexibility and to slowly “demote” Google instead of hard quitting: keep Google + add pCloud/Sync.com + glue them with CloudMounter.
Personally, I’d start with pCloud or Sync.com as the main Drive replacement, move your sensitive/large archives there, keep Google only for real-time docs, and use CloudMounter so it all shows up like one big storage universe on your machine. That setup actually reduces the chaos instead of just trading one logo for another.
You’re not crazy, Google Drive does start to feel cramped and flaky once you hit that “too much stuff, not enough control” phase.
I mostly agree with @mikeappsreviewer and @espritlibre on splitting things across services, but I’d actually push you a bit more toward choosing a “primary home” first, then layering on others only where it truly helps. Otherwise you just recreate chaos with extra steps.
Here’s what I’d look at, in practice:
1. If you want one main replacement that “just works”: Dropbox
Yeah, boring pick, but for everyday use it’s still the smoothest combo of:
  • Fast, reliable sync (especially lots of small files)
  • Works on basically everything
  • Decent sharing and version history
You will pay more than with Drive once you go above free tier, and privacy is not magical here either, but if your main issue is storage limits and slow sync, Dropbox fixes those quicker than anything else.
Use case:
  • Make Dropbox your main “Documents” home
  • Leave Drive for shared Google Docs only
  • Slowly migrate old Drive archives into Dropbox when you touch them
2. If privacy / data control are top priority: Sync.com or Tresorit
People already mentioned Sync.com and pCloud; I’d add Tresorit if you are serious about security and willing to pay for it.
  • Zero knowledge encryption
  • Strong focus on security and compliance
  • No “oops we scanned your files for AI training” vibe
  • More expensive
  • Collaboration is more like “share this folder” and less like “live edit like Docs”
This is better if your brain goes “I want my stuff locked down first, convenience second.”
3. If you want real control: NAS + a lean cloud
Where I disagree slightly with the others: self‑hosting doesn’t have to mean renting a VPS and becoming part‑time sysadmin. If you’re willing to spend a bit up front, a simple NAS box (Synology or QNAP) on your home network plus a small cloud plan can be a killer combo.
Basic pattern:
  • NAS at home
    • Acts as your main storage and backup
    • You control the disks and location
  • Smaller cloud account (Dropbox / pCloud / Sync.com)
    • For sharing and for “must access anywhere” files
Most NAS systems have mobile and desktop apps that work a lot like Drive. Sync is usually fine unless your upload speed is garbage.
4. Unifying stuff without going insane: CloudMounter
Here’s where I do agree with the multi‑cloud camp, but with one twist: only do it if you pair it with a tool like CloudMounter.
CloudMounter is handy because:
  • It mounts multiple clouds in Finder like drives
  • No need to fully sync everything to your disk
  • Plays nice with Google Drive, Dropbox, OneDrive, pCloud, WebDAV, SFTP and so on
So if you decide to:
  • Keep a free / small Google Drive just for Docs
  • Move bulk personal files to pCloud or Sync.com
  • Keep work files on OneDrive
Then CloudMounter lets you see them all in one place so you are not hunting through three web UIs trying to remember where “invoice_final_FINAL.pdf” lives. That solves the “too many silos” problem that killed a lot of people’s first attempts to leave Drive.
5. A concrete setup that stays sane
If I were in your shoes right now and wanted less Google, more control, but no full-time IT job:
  1. Pick one primary:
    • Wants speed & convenience: Dropbox
    • Wants privacy: Sync.com or pCloud
  2. Demote Google Drive:
    • Keep it only for Docs / Sheets collab
    • Delete or archive old junk that you never open
  3. Use CloudMounter on desktop:
    • Mount Google Drive + your new primary cloud
    • Optional: add OneDrive/iCloud if you already use them
  4. For really important stuff:
    • Keep a local backup on an external SSD
    • Once in a while, unplug it and store it somewhere safe so you are not depending on any cloud at all
That way you actually solve your three issues:
  • Storage limits: more generous primary provider, plus local storage
  • Slow syncing: better sync engine + on‑demand mounting via CloudMounter
  • Privacy / control: at least one provider that is not scanning your stuff, plus your own offline copy
It’s not about finding The One True Google Drive Clone, it’s about picking one main home, then using the other tools in a way that doesn’t multiply the mess.
If Google Drive feels cramped and twitchy, I’d stop hunting for a single “perfect” clone and instead fix two separate problems:
  1. where your files live, and
  2. how you access all those places.
@espritlibre and @techchizkid already covered solid privacy‑centric and vendor‑lock‑in angles, and @mikeappsreviewer described the multi‑cloud approach well. I slightly disagree with the idea that you must commit hard to just one primary cloud; for a lot of people, light fragmentation is fine as long as access is unified.
1. Storage & privacy: where to move your stuff
Concrete, everyday‑use options:
  • pCloud / Sync.com
    Good if you care about privacy and one‑time or low‑drama pricing. Client‑side encryption, decent desktop apps, not tied to a giant ad company. Slower “feel” than Dropbox for lots of tiny files, but miles better for privacy than simply jumping to another big tech provider.
  • Dropbox
    Still the most “it just syncs and I forget about it” option. If your main pain is slow syncing and storage juggling, it often solves that fast. You lose a bit on privacy compared to something zero knowledge, but you gain in polish and reliability.
My take:
• Move archives and sensitive stuff to pCloud/Sync.com.
• Keep something like Dropbox or OneDrive only if you absolutely need the smoother collab, or your job dictates it.
• Let Google Drive shrink down to a collab / Google Docs island instead of your entire digital life.
2. Access & sanity: how to stop juggling 4 different apps
This is where a lot of people get stuck. They move off Drive, then end up hunting: “Was that in Dropbox? pCloud? Drive?” That is the part you actually want to fix.
A practical tool here is CloudMounter:
CloudMounter pros
  • Mounts multiple clouds (Google Drive, Dropbox, OneDrive, pCloud, WebDAV, SFTP, etc.) as network drives in Finder.
  • No need to sync gigantic folders locally, so your laptop SSD does not suffocate.
  • Lets you treat each cloud like an external drive: plug in when needed, ignore when not.
  • Works especially well if you keep old archives in slower / cheaper storage and only mount them occasionally.
CloudMounter cons
  • Requires a paid license; not a “free forever” toy.
  • Network‑drive style access can feel slower than native sync for huge projects you open constantly. You will still want local sync for your most active working folder.
  • Desktop‑centric mindset. If you mostly live on mobile devices, the benefit is smaller.
So instead of fully following @mikeappsreviewer’s “2+ clouds by design” or trying to stay ultra minimal, I’d do something in between:
  • Pick one privacy‑respecting cloud as your main home for personal stuff (pCloud or Sync.com).
  • Let Google Drive live on strictly for Google Docs / Sheets and shared links.
  • Optionally keep Dropbox or OneDrive around if work requires it.
  • Use CloudMounter on your main computer so all of those show up in one file browser, without everything syncing down.
Result:
  • Storage limits stop being a daily problem, because you are not married to only one 15 GB cap.
  • Sync speed improves where it matters, because only your “active” folder is truly local.
  • Privacy and control are better, since the bulk of your data sits in a provider you chose for that reason, plus you can still add an external SSD backup on top.
You are not forced to pick “the next Google Drive.” You give Drive a smaller, well‑defined role and let CloudMounter plus one or two carefully chosen providers do the real work.
Try a no cloud core with Syncthing. It syncs devices peer to peer, fast, free, open source. Your files live on your gear, not a vendor. Add Backblaze Personal Backup on one alwyas on machine for offsite safety. Steps: install Syncthing on laptop, desktop, phone. Pick a prmary folder. Turn on versioning for 30 days. Install Backblaze on the desktop. LAN sync hits local network speed, often 100 to 900 Mbps. My 80 GB project mirrored in under 40 minutes on gigabit. Storage limits go away. Privacy improves. You keep control without juggling providers.
