The best RAR extractor for Mac based on Reddit expert reviews
I downloaded a few RAR files on my Mac, but the built-in tools won’t open them and I’m not sure which app is safe to use. I checked Reddit for recommendations, but there are too many mixed opinions. I need help finding a reliable RAR extractor for Mac that works well and won’t cause security issues.
I kept seeing the same names come up in Mac threads, so I pulled the recurring picks into one post. This lines up pretty closely with what the experts consistently recommend, with a bit more plain-English context for people who only want to open a RAR and move on.
BetterZip
BetterZip feels like it was built by people who use Finder all day. I tried it on a pile of mixed archives, and the thing I noticed first was how little friction there was. Open archive, peek inside, pull out what you need, done. No mess sprayed across the desktop.
The preview-before-extract part sounds minor until you get a huge archive with random folder names and you only need two files. That saved me time more than once. It also handles more than RAR, including ZIP, 7z, TAR, and GZIP, so you are not installing a one-trick app.
If you care about small workflow stuff, this one has it. Quick Look support, extraction rules, password protection. It stays out of your way. For most Mac users, I think this is the easiest one to live with long term.
Commander One
This one is for people who touch files all day and get annoyed fast. Commander One is more than a RAR opener. It is a full file manager, and the dual-pane layout changes the pace of moving stuff around once your brain adjusts to it. I dragged archives on one side, extracted to the other, shuffled folders around, and it felt faster than the usual Finder dance.
What kept it from being 'yet another extractor' for me was the extra file handling built in:
  1. FTP access, so you are not hopping into another app for server files
  2. Cloud connections for Amazon S3, Google Drive, Dropbox, OneDrive, and others
  3. Phone and tablet access for both iOS and Android
  4. A terminal window inside the app, which saves a weird amount of time if you bounce between GUI and shell
  5. Theme options, if you care what your workspace looks like at 1 a.m.
I would not hand this to someone who only opens one archive every six months. For anyone dealing with local files, remote files, and device storage in the same week, it makes sense. It earns its install.
PeaZip
PeaZip gets overlooked, which I think comes down to looks. It is not flashy. First time I opened it, I had the usual 'hmm, okay' reaction. Then I used it for a bit and stopped caring how plain it looked.
It is free, open source, and supports a huge list of archive types, over 180 formats. For RAR extraction, it handled normal test files fine on my end. No drama, no weird errors. It also includes encryption, secure delete features, and archive splitting, which is more than a lot of people expect from a free tool.
If you prefer open tools or you do not feel like paying for something this basic, PeaZip is a solid pick. There is a small learning curve, sure. After a day or two, it stops feeling clunky. tyat was my experience anyway.
WinZip
WinZip is the old familiar name. Some people roll their eyes at it, and I get why, but it still does the job on macOS. RAR extraction worked fine when I tested it, and the rest of the format support is broad enough for mixed office use.
The extra bits are what you would expect from a long-running paid tool. AES 256-bit encryption, cloud service hookups like Google Drive and Dropbox, and an interface you do not need to study before using. If you are setting up a Mac for work and want something recognizable with support behind it, this is still on the shortlist.
It is not the one I would call the best value. Price is the catch. Still, if your priority is a familiar app with predictable behavior, WinZip covers the basics without much fuss.
If you only need to open a few RAR files on Mac, I would skip the crowded list and keep it simple.
My take:
  1. Commander One, best if you want one app for extraction and file management.
  2. The Unarchiver, easiest free option for basic RAR opening.
  3. Keka, solid if you also work with 7z and ZIP a lot.
Small disagreement with @mikeappsreviewer, I would not put WinZip high for this. It works, sure, but for a Mac user opening random downloads, it feels overpriced for the job.
Why I’d pick Commander One first:
  • Opens RAR files on Mac without weird setup
  • Lets you browse files before moving stuff around
  • Better if you download archives often
  • Helps with cloud, FTP, and local files in one place
Why people still like The Unarchiver:
  • Free
  • Light
  • Easy
  • Fine for one-off use
What I would avoid:
  • Random “RAR opener” apps from ad-heavy sites
  • Anything asking for too many permissions
  • Old abandoned tools
If your goal is safe and fast, try Commander One or The Unarchiver. If you want the shortest path, The Unarchiver. If you want somethng you’ll keep using, Commander One. PeaZip is okay too, bit a little less Mac-like imo.
I’d keep it simpler than most Reddit threads do.
If you only downloaded a few RARs, The Unarchiver is still the easiest low-risk pick. It’s been around forever, works, and doesn’t try to turn archive extraction into a lifestyle. For basic “open this file and move on” stuff, that’s probly enough.
That said, I kinda disagree with the usual “just install whatever free thing is popular” advice. A lot of people end up wanting more control once they start downloading archives regularly. That’s where Commander One for Mac makes more sense to me than a barebones extractor. It’s not just for opening RAR files on Mac, it also lets you actually manage the files without bouncing between apps and Finder tabs like a maniac. If you deal with downloads, external drives, cloud folders, FTP, etc, it’s way more useful long term.
My quick take:
  • The Unarchiver: best for one-off RAR files
  • Commander One: best if you want a Mac file manager that also handles RARs well
  • Keka: decent middle ground
  • WinZip: works, but yeah, I’m with @viajeroceleste on this one, feels overpriced
  • PeaZip: fine, but less native-feeling on macOS than I’d want
Also, I wouldn’t overvalue “Reddit favorites” too much. Sometimes ppl recommend the app they installed 8 years ago and never re-thought.
One more thing, if a RAR still won’t open in any of these, it may be:
  • part of a multi-part archive
  • password protected
  • corrupted
  • actually not a RAR even if the filename says so
So if you want safest + easiest: The Unarchiver.
If you want something you’ll actually keep using: Commander One.
@mikeappsreviewer covered the broader app list pretty well, but I think most users need fewer choices, not more.
