Recuva Flagged By Antivirus, Is Recuva Safe?
I downloaded Recuva to recover deleted files, but my antivirus flagged it during the install. Now I’m not sure if it’s a false positive, bundled software issue, or something unsafe. I need help figuring out if Recuva is safe to use and what I should check before installing it.
People ask this all the time, and the short answer is plain enough. Yes, Recuva is safe to run. It is not malware. It is not a fake cleaner app waiting to trash your PC. Still, 'safe' splits into a few different things. Safe to install is one part. Safe for your privacy is another. Safe for the files you already lost, weirdly, is where most people mess it up.
I used Recuva on a few test drives, one old laptop SSD, and a USB stick I formatted by mistake at 2 a.m. Some runs went fine. Some were useless. One almost got worse because I got lazy and wrote to the same disk. So here’s the version I wish someone gave me before I touched anything.
About the malware scare
If you heard about the old Piriform mess, yes, that happened. Recuva comes from the same company line as CCleaner, and back in 2017 the CCleaner supply chain attack was a huge screwup. Official update, malicious payload, millions exposed. People still bring it up because they should.
Still, 2026 is not 2017. Ownership changed. Piriform ended up under Avast, then Gen Digital. The current Recuva installer, when pulled from the official source, usually scans clean. If you toss it into VirusTotal, you might spot one stray alert from some tiny antivirus engine nobody uses. I saw that too. In practice, it tends to be heuristic noise because file recovery tools poke around low-level disk areas and security apps sometimes hate that.
If you download it from the official CCleaner or Piriform page, the virus risk looks low.
Privacy, which is a different argument
This part is less dramatic and more annoying. Recuva itself is not spying in some movie-villain way, but the company does gather routine app and device data. Things like IP address, device ID, Windows version, and location data tied to licensing and fraud controls. Normal software-company behavior, if you want to call it normal. I still turn it off when I can.
After install, open Options, then Privacy, and untick 'Help improve our other apps by sending usage data.' I did this right away. You should too if you care about limiting the extra chatter.
One detail people skip, they keep IP logs for up to 36 months before anonymizing them. For a free tool, that tradeoff might bug you. Depends on your tolerance.
The part that matters most, do not write to the same drive
This is where files go from recoverable to dead.
Recuva does not usually destroy your data on its own. Users do. If the deleted files were on Drive D, do not install Recuva on Drive D. Do not save the recovered files back to Drive D either. I know this sounds obvious after the fact. In the moment, people click through fast and wreck their own shot.
Deleted files often still sit on disk until new data lands over them. Windows removes the reference first. The content stays until overwritten. So if you put the installer, temp files, scan logs, or recovered output onto the same storage, you raise the odds of stomping on the thing you wanted back.
The safer move is the portable build. Put it on a USB drive and run it from there. Recover files onto another disk, external drive, or at least a different physical device. A different partition is better than the same partition, but a separate drive is the cleaner move.
How well it works in real use
Here’s the blunt part. Recuva still works for easy jobs. It does not feel built for messy ones.
If you deleted a folder from a healthy Windows machine ten minutes ago and emptied the Recycle Bin, I’d try Recuva first too. It is light, quick, and free without the fake limits a lot of recovery apps throw at you now. For simple undelete cases, it still earns its place.
But old bones show. The core app has not had a major rebuild in years. There were small updates to keep it alive on newer Windows versions, sure, but it still behaves like an old-school undelete utility, not a fuller recovery platform.
My results were mixed. On one formatted flash drive, it found a bunch of filenames, then half the photos opened broken. I also got the classic mess where recovered files lost their folder tree and dumped into one pile with renamed junk like 000001.jpg, 000002.jpg, and so on. Sorting that by hand is miserable.
On damaged or weird disks, it drops off fast. If Windows shows the drive as RAW or asks you to format it before use, Recuva often fails before the scan even gets going. It usually wants a visible and healthy partition. On formatted USB tests, people often report recovery in the rough 63% to 67% range. That lines up with what I saw, not exact, but close enough to feel believable. The bigger issue was file integrity. Finding a file entry is not the same as getting a working file back.
When I’d stop using it
If the files matter, like tax docs, work material, family photos, or the only copy of something, I would not spend hours rerunning Recuva after the first weak result. Drives in bad shape do not improve because you keep hoping harder. Every extra read puts more wear on a failing device.
That is the point where I’d move to a stronger tool. If the disk is RAW, the partition is damaged, the file system is odd, or the recovered files keep coming back corrupt, Recuva is out of its depth.
I had better luck with Disk Drill in those cases. It handled damaged partitions Recuva ignored. It also did better on formatted media and on mixed file types. The big thing for me was disk imaging. Byte-to-byte imaging lets you clone the failing drive first, then scan the clone instead of hammering the original hardware. If the source drive dies in the middle, you still have the image. Recuva does not give you that cushion.
Media files are another sore spot. If you shoot video, or use Nikon NEF, Canon CR3, or other camera RAW formats, Recuva gets shaky fast, especially with fragmented files. I learned this the hard way with a chopped-up MP4 from an SD card. It 'recovered' the file. The file would not play. Great, thanks. If you want a side-by-side look, this review is worth watching.
What I’d do, step by step
  1. Get Recuva from the official source only.
  2. Pick the portable version if you have the option.
  3. Run it from a USB drive, not from the disk with the deleted files.
  4. Turn off usage sharing in the privacy settings.
  5. Save recovered files to another drive.
  6. If the first scan looks bad, stop and reassess.
My take
If you need a free first pass on a healthy Windows system after a simple deletion, Recuva is still a fair tool. Safe enough to install. Easy enough for beginners. Fast enough for quick checks.
If your case is messy, I would keep my expectations low. Recuva is decent at the easy stuff and shakier once the job stops being clean. If it misses files, finds them broken, or refuses to read the disk, stop using the drive and switch tools before you make a bad situation worse.
That’s the whole thing. Safe app, with privacy tradeoffs, and a lot of user error wrapped around it. Use it carefully or don’t use it at all. That part matters more than the download button.
If your antivirus flagged Recuva, I would not call it instant proof of malware. A lot of AV tools hate file recovery apps because they read raw disk data, touch deleted entries, and sometimes bundle optional offers in the installer. That combo trips heuristics.
My take is a bit stricter than @mikeappsreviewer on one point. I would skip the normal installer entirely. Use the portable build if you can find it from the official source. The installer has had bundled offer baggage before, and that is where some flags come from. If you got Recuva from Softonic, FileHorse, random mirrors, or a forum upload, delete it. Re-download from the official vendor site only.
Quick checks:
  1. Right click the file, check digital signature.
  2. Upload the installer to VirusTotal.
  3. Look at how many engines flag it. 1 to 3 obscure engines is often noise. 15+ is bad news.
  4. Compare the file hash with the official one if listed.
Recuva itself is usually safe. The bigger issue is whether it is the right tool. For simple accidental deletes on a healthy drive, sure. For formatted drives, RAW partitions, corrupted file systems, or damaged media, it gets weak fast. In those cases I’d move to Disk Drill sooner rather than later. It handles tougher recovery jobs better and gives you more control.
Also, stop installing stuff onto the same drive you want to recover from. That part ruins more recoveries than antivirus flags do, tbh.
If you want a cleaner list of data recovery tools worth checking, this guide helps:
best data recovery software for deleted files and damaged drives
AV flagging Recuva during install does not automatically mean Recuva is dangerous. Most of the time it comes down to 3 things:
  • the installer includes optional bundled junk or ad-like offers
  • recovery tools access disk sectors in ways AV engines dislike
  • you downloaded it from somewhere sketchy
I agree with parts of what @mikeappsreviewer and @yozora said, but I’m a little less relaxed about the installer itself. The app’s reputation is mostly fine, but the installer experience is where false positives and PUP detections tend to happen. That’s an important differece people blur together.
So, is Recuva safe? Usually yes, if it came from the official source and the detection is a generic heuristic or PUP warning. If your antivirus is calling it a trojan by a major engine, that’s a diffrent story.
What I’d pay attention to:
  • Detection name matters
    “PUA/PUP”, “suspicious”, “generic”, “heuristic” = often not serious malware
    “Trojan”, “Backdoor”, “Stealer” from several major vendors = stop
  • Source matters more than the app name
    Official download: lower risk
    Download portal / mirror / cracked copy: nope
  • Installer vs portable
    This is the one place I slightly disagree with the “it’s safe enough” crowd. If there’s a portable version, I’d use that instead. Less junk, fewer installer-related flags, less chance of writing to the wrong drive.
Also, people get so focused on the AV alert that they forget the actual recovery risk. Installing anything onto the same drive you’re trying to recover from is how deleted files turn into permanently gone files. That part is way more dangerous than one generic AV popup, tbh.
If Recuva is just for a simple accidental delete on a healthy drive, it’s still usable. If the drive is corrupted, formatted, RAW, or acting weird, I wouldn’t keep forcing Recuva to be the hero. That’s where Disk Drill is usually the better data recovery software option because it handles tougher cases with more flexibility.
For basic background on the tool itself, here’s a decent overview of what Recuva file recovery software actually is.
Short version:
Safe enough? Probably.
Trust the installer blindly? Not really.
Use it from the same drive you’re recovering? Absolutely not.
I’m slightly less trusting than @yozora, @viajeroceleste, and @mikeappsreviewer on one point: even if Recuva itself is legit, an AV hit during install is often about the installer wrapper, not the recovery engine. So “safe” depends on what exactly got flagged.
What I’d look at first:
  • Was it flagged as a PUP/PUA? That is usually bundled-offer territory.
  • Was it flagged as a trojan by several major vendors? Different story.
  • Did you get it from the official publisher, or from a download site that repackages installers?
Also, some antivirus products really dislike undelete tools because they enumerate deleted records and read disk structures directly. That behavior can look shady even when it is not.
One thing I disagree with a little: people jump straight to “false positive” too fast. Sometimes the file is clean, but the installer is still annoying enough that I would avoid it. If there is a portable build, that is the safer route.
As for actual recovery quality, Recuva is fine for basic accidental deletes. Once the drive is formatted, corrupted, or showing RAW, it starts feeling old. That’s where Disk Drill usually makes more sense.
Disk Drill pros:
  • better with tougher recoveries
  • can image failing drives
  • cleaner modern workflow
Disk Drill cons:
  • not as lightweight
  • deeper scans can take a while
  • free recovery limits depend on platform/version
So yes, Recuva can be safe, but I would trust the source, not the name. If the warning looks serious or the drive problem is more than a simple delete, skip the gamble and use Disk Drill instead.
You covered the core points. AV hit often means PUP or heuristics. Source matters more than the name. Prefer portable. Never write to the target drive. Recuva works for easy undeletes. Disk Drill fits hard jobs and imaging. Privacy toggles matter.
Simpler path: use Windows Previous Versions or File History. Rigth-click the parent folder, Properties, Previous Versions, pick a date, Restore or Open and copy out. If files lived in OneDrive, use Version history on the web and restore. Zero installs, zero risk to overwrite. I have seen this save full photo sets minutes after deletion.
