Need help with the TikTok app on my phone
My TikTok app has been acting weird lately: videos won’t load properly, the feed keeps freezing, and sometimes the app crashes as soon as I open it. I’ve already tried basic fixes like restarting my phone, clearing the cache, and reinstalling the app, but nothing has worked. I need help figuring out what might be causing these TikTok app issues and what else I can try to get it working normally again.
Seen this a lot with TikTok lately. If you already cleared cache and restarted, try these in order:
  1. Check your connection
  • Test with a browser speed test.
  • TikTok needs stable 5 Mbps or more for smooth video.
  • Switch between WiFi and mobile data. If one works and the other sucks, the issue is network, not the app.
  1. Force stop and clear data
    Android:
  • Settings > Apps > TikTok > Force stop.
  • Then Storage > Clear cache again, then Clear data.
    iPhone:
  • Offload the app in Settings > General > iPhone Storage > TikTok > Offload App.
  • Reinstall from App Store.
    You will need to log in again.
  1. Check storage and RAM
  • Make sure you have at least 3–5 GB free storage. TikTok gets weird when space is low.
  • Close other heavy apps before opening TikTok.
  1. Update or rollback
  • Update TikTok from Play Store or App Store.
  • If the issue started after a recent update on Android, try installing an older version from a trusted APK mirror. This is more technical and you need to be careful where you download from.
  1. Turn off VPN, ad blockers, DNS apps
  • If you use VPN, DNS changer, Blokada, etc, turn them off and test.
  • Some of these break video loading or cause feed freezing.
  1. Reset network settings
    Android: Settings > System > Reset options > Reset WiFi, mobile and Bluetooth.
    iPhone: Settings > General > Transfer or Reset > Reset > Reset Network Settings.
    You will lose saved WiFi networks and Bluetooth pairings, so write down any passwords first.
  2. Check for system updates
  • Update your phone’s OS.
  • On older devices TikTok often crashes more after a few app updates.
  1. Log out and log in again
  • Profile > Menu > Settings and privacy > Log out.
  • Then log back in.
    Sometimes the feed bug is tied to account session data.
  1. Test with another account or device
  • Log into another TikTok account on your phone.
    If that works fine, your main account might be throttled or bugged server side.
  • Log into your account on another phone or on tiktok.com in a browser.
    If it works there but not on your phone, it is device or app level.
  1. Reinstall clean
  • Delete TikTok.
  • Reboot phone.
  • Install again, but before logging in, test as guest to see if videos load.
    If it works as guest but breaks after login, the problem is linked to your account settings or followed content.
  1. Check TikTok server status
  • Search “TikTok down” on DownDetector or Twitter.
    If many users report the same thing at the same time, you just wait it out.
If you post your phone model, OS version, and TikTok version, people here can give more targeted advice. Right now it sounds like either network shaping from your ISP or a buggy TikTok version on your specific device.
Couple things to add on top of what @viajeroceleste said, from the “I’ve broken TikTok 10 different ways” experience:
  1. Check TikTok’s in‑app playback settings
    • Profile > Menu > Settings & privacy > Data saver / Video quality.
    • Turn OFF Data Saver and any “auto” quality limiter. Sometimes it bugs out and keeps forcing ultra‑low bitrate that never loads.
    • Disable “Upload HD by default” if you post a lot. Sounds unrelated, but on some phones TikTok gets super unstable when it’s trying to handle big drafts + HD uploads.
  2. Kill problematic “overlay” apps
    Stuff like chat bubbles, screen filters, floating toolbars, “blue light” apps, even some screen recorders. On Android especially, these can make TikTok freeze or crash at launch.
    • Temporarily turn off anything that draws over other apps.
    • Then launch TikTok a few times in a row and see if it still dies.
  3. Check for phone overheating / throttling
    TikTok is a resource hog. If your phone is older or already hot:
    • Try right after a cold reboot, phone unplugged from charger.
    • If you notice it crashes way more when it’s warm or charging, that’s usually thermal throttling + TikTok being badly optimized for your device.
  4. Look at permissions
    • Make sure TikTok has Storage / Photos permission.
    • On Android, disable “Remove permissions if app is unused” for TikTok.
      Sometimes the OS quietly revokes something, TikTok freaks out, and instead of giving a clear error it just… dies.
  5. Try switching region‑related stuff
    This is where I slightly disagree with the blanket “turn off VPN” thing.
    • If TikTok is heavily throttled in your region or by your ISP, sometimes a fast VPN actually makes it more stable, not less.
    • The trick is to test both: VPN off first, then a reliable, low‑latency VPN location (nearby country) and compare.
      If both are bad, then yeah, VPN is not the cure.
  6. Check if it’s only your “For You” feed
    • Search a random hashtag, open some videos from there.
    • Check the Following tab too.
      If search / Following work fine but For You freezes, it can be an account‑feed bug. In that case:
    • Mute / unfollow a few super spammy or live‑selling accounts.
    • Turn off “Autoplay next video” in settings if available.
      This sometimes “unclogs” a cursed feed for me.
  7. Drafts & saved effects
    TikTok gets really flaky when:
    • You have dozens of big drafts stored. Try deleting old drafts you 100% don’t need.
    • A specific effect or filter you used in drafts gets removed or updated. Open drafts, see if any error out or refuse to load, then delete the broken ones.
  8. Check battery & performance modes
    • Disable any “battery saver” / “ultra power save” mode.
    • On some Android skins, set TikTok to “No restrictions” under battery / performance management.
      Aggressive battery tuning can literally kill the app mid‑scroll and make it look like a TikTok issue.
  9. System‑level adblocking / private DNS
    I’d go further than just VPN / adblock apps:
    • If you use private DNS (like dns.adguard.com or 1.1.1.1 for Families), turn it off.
    • Some routers have built‑in adblocking that specifically hates TikTok’s CDN. Try a different WiFi network entirely, like a friend’s or public hotspot, and see if it behaves normally.
  10. If nothing works, isolate what exactly is broken
    Answer these for yourself:
  • Do downloaded / drafts play fine, but feed videos don’t load?
  • Does it crash only on profile pages, only when going to DMs, or literally at open?
  • Does it behave better on cellular than WiFi or the opposite?
    The pattern usually points to:
  • Network / ISP issue
  • Specific feature/section bug
  • Device being borderline too weak / low on resources for the current TikTok version
If you post your phone model + OS + whether it’s worse on WiFi or data, people can probably pinpoint it faster. Right now, with “freezing + crashing at open,” my money is on a mix of low resources + one background app interfering, or some cursed combination of drafts/effects and a recent TikTok update.
Couple of extra angles that @himmelsjager and @viajeroceleste did not fully dig into:
  1. Check TikTok’s internal bug reports
    • In TikTok: Profile → Menu → Settings & privacy → Report a problem.
    • Run through a report under “Video playback” or “App crashes” and attach a screen recording if you can.
      TikTok actually does tweak individual account flags behind the scenes after enough reports. It is slow, but useful if your account itself is glitched.
  2. Time‑of‑day & ISP shaping
    They both touched on network, but not the pattern side of it.
    • Note when it is worst (evening only, on home WiFi only).
    • If it is awful only at certain hours on one network, your ISP may be throttling TikTok specifically. In that case, TikTok will feel broken even though other apps seem fine. A different WiFi (work, friend’s) is the best A/B test here.
  3. Account “weight” issues
    • If you follow thousands of accounts, get flooded by Lives, or have huge block/mute lists, the app sometimes chokes when building your For You.
    • Try trimming: unfollow inactive accounts, clear old blocked accounts you do not remember, turn off unnecessary notifications. This is annoying housekeeping but can reduce how much data has to refresh when you open the app.
  4. Deep clean without nuking your whole phone
    People often jump to full device reset too early. I would not do that yet. Instead:
    • Remove old social apps you never use that still have background access.
    • Disable auto‑start for nonessential apps in your phone’s settings.
      This frees resources for TikTok without wiping everything.
  5. Watch for manufacturer “optimization”
    Some brands have aggressive optimization that kills heavy apps quietly.
    • In your phone settings, look for something like “App optimization,” “Auto manage,” or “Smart manager.”
    • Explicitly exclude TikTok from automatic optimization.
      Here I slightly disagree with the idea of only changing battery saver: sometimes you must turn off the brand’s “smart” app control just for TikTok.
  6. Camera & microphone conflicts
    If crashes happen right when you open the camera or go to create a video:
    • Temporarily revoke and re‑grant camera/mic permissions.
    • Close or uninstall any third‑party camera overlay or beauty filter apps.
      Conflicts here can crash the entire app while the feed seems fine.
  7. System logs & crash pattern
    If you are comfortable with tech:
    • On Android, use adb logcat while you open TikTok and see if the crash is memory, graphics, or network related.
    • On iOS, in Settings → Privacy & Security → Analytics & Improvements → Analytics Data, check recent TikTok crash logs.
      If you see repeated graphics or renderer errors, lowering system animation scale or disabling high refresh rate for TikTok can sometimes help.
  8. When to stop fighting and wait
    If TikTok works on:
    • Another device with your account
    • Your device with another account
      but not “your account on your device,” after you have tried the basics and the extra steps above, you are likely looking at a server side or account‑specific bug. That is the point where further local tweaks are mostly placebo and you wait for a TikTok update or a backend fix.
Quick note on @himmelsjager and @viajeroceleste: both gave solid, real‑world steps. I am a bit more cautious than they are about rolling back to older APKs and constantly toggling VPNs, since that can introduce more instability than it solves if you are not careful. Focus first on patterns (when/how it breaks) and on trimming how “heavy” your account and device environment are.
Your reply goes beyond basics, covering account weight, ISP patterns, phone optimizations, camera conflicts, and logs. Good call avoidng APK rollbacks and VPN hopping.
Simpler fix, bypass the app:
  • Open tiktok.com in Chrome or Safari, sign in, add to Home Screen as a defualt shortcut.
  • In Settings, turn off autoplay and HD upload to reduce load.
  • Use this for 24 hours on Wi‑Fi and mobile to compare.
    If web runs smooth, the issue is the app build on your device, not your network. Then wait for the next update.
