Need help with cross-platform app development by Garage2Global
I’m working on a cross-platform app project using Garage2Global’s tools and I’m struggling to understand the best way to optimize performance and maintain a single codebase for iOS and Android. I’ve run into issues with device compatibility, UI consistency, and build errors that I can’t fully debug. Can anyone explain recommended best practices or share a step-by-step approach for setting up and managing a stable cross-platform app with Garage2Global so I can move forward confidently?
Few concrete things that help with Garage2Global cross platform stuff:
  1. Shared core, thin native shells
    Split your app into:
  • Shared logic layer: networking, models, validation, state, business rules
  • Platform layer: navigation, permissions, push, UI quirks
Keep 90% of code in the shared layer. Only branch for platform when you hit:
  • Native APIs
  • UX that must follow iOS / Android patterns
Use clear folder structure:
  • /core
  • /platform/ios
  • /platform/android
This avoids “if (ios) … else …” all over.
  1. Avoid heavy UI abstraction
    If Garage2Global offers a “one UI to rule them all” abstraction, use it only for:
  • Simple lists
  • Forms
  • Settings screens
For complex stuff, call into platform specific views. Wrap those in a common interface so the shared code talks to “ProfileView” rather than UIKit or Jetpack Compose directly.
  1. Watch performance hot spots
    The usual slow points on cross platform:
  • Chatty bridge between native and shared layer
  • Re-rendering big lists or grids
  • Heavy JSON parsing on main thread
Concrete fixes:
  • Batch bridge calls. Pass arrays of data, not single items in loops.
  • Use pagination and windowing for lists.
  • Move serialization and heavy logic off main thread if the tools support background workers.
  1. Reduce platform conditionals
    If you find if (isIOS) and if (isAndroid) all over, create interfaces instead.
Example:
interface FilePicker {
fun pickImage(): FileResult
Then implement:
  • IOSFilePicker
  • AndroidFilePicker
Register the right one per platform. Your core code stays clean.
  1. Feature flags and env
    Use feature flags when you must roll out platform differences over time.
    Config per environment:
  • dev-ios
  • dev-android
  • prod-ios
  • prod-android
Saves you from “why does this screen crash only on Android prod”.
  1. Testing strategy
  • Unit tests only hit shared core.
  • A few UI tests per platform cover nav and integration.
  • Run performance tests on older Android and older iPhone, not only on flagship phones.
Quite a few teams I saw got 85–90% shared code using this pattern, with stable perf on both platforms. The tradeoff is slightly less “pure” abstraction, but debugging stays saner and perf issues stay localized.
If you share what issues you hit exactly, like slow startup or frame drops on a specific screen, you will get more targetted tips.
Couple of angles that complement what @viajantedoceu already laid out, focusing more on how to keep perf sane over time and keep the “single codebase” from turning into a myth.
  1. Measure before you “optimize”
    Garage2Global’s tooling is pretty decent at hiding where time is spent, which is dangerous. Before changing architecture again, wire in:
  • cold start timers per platform
  • screen transition timing (time from “navigate” call to first frame rendered)
  • a simple FPS / dropped frames counter for your heaviest screens
Even crude logging like t0 = now() at app start and after first main screen is loaded helps. You’ll find 1–2 screens or flows are causing 80% of the pain.
  1. Decide what “single codebase” actually means
    People get stuck trying to keep 100% identical code. That’s often the wrong target.
The pattern I’ve seen work with Garage2Global:
  • 100% shared: models, networking, validation, feature flags, analytics events
  • 80–90% shared: feature logic & state machines
  • 60–80% shared: navigation flow contracts, view-models
  • 40–60% shared: actual UI widgets
If you’re fighting the framework to keep some fancy gesture or animation “shared,” it’s usually cheaper to split that particular UI into platform code and keep the logic shared. “Single codebase” at the logic layer is way more valuable than “single codebase” for every pixel.
  1. Lean on “view-model + dumb view” aggressively
    Don’t let platform specifics leak into your business logic. Use something like:
  • ViewModel in shared layer exposes:
    • state: immutable data structure
    • effects: one-off actions like “openFilePicker” or “showErrorToast”
    • inputs: methods like onSubmitClicked(), onItemSelected(id)
  • Native views (Swift / Kotlin) are “dumb”:
    • subscribe to state
    • render with native components
    • translate user gestures back to view-model inputs
That way:
  • perf issues in rendering stay on the platform side
  • logic perf issues (like huge JSON or sorting) are obviously in the shared layer
  • it’s testable without spinning up a simulator
  1. Avoid clever abstraction around animations and navigation
    I’ll disagree a bit with the idea of keeping too much navigation logic in a common abstraction. Cross platform “navigation frameworks” in Garage2Global sound nice but often cause:
  • extra indirection at runtime
  • weird back-stack behavior on Android
  • modals behaving wrong on iOS
Instead:
  • Keep the navigation graph (which screen connects to which) as a shared concept
  • Let each platform wire it into its native navigator directly
  • Define screen identifiers and required params in the shared layer so at least you don’t fork logic around what data each screen needs
Animations: keep them native unless they are dead simple. Shared animation engines tend to be a perf trap on older Android.
  1. Data loading strategy matters more than UI tech
    Most “the app feels slow” complaints I’ve seen on Garage2Global projects ended up being:
  • chatty APIs
  • loading way too much data “just in case”
  • no caching at all
Stuff that helps a ton:
  • Caching layer in shared core with a clear policy: memory + disk + TTL
  • Stale-while-revalidate: show cached data instantly, refresh in background
  • Partial loading: first fold, then rest
    This keeps both platforms snappy without doing platform-specific hacks.
  1. Treat the bridge as hostile territory
    Any time you cross from shared core to native and back, pretend you pay a tax:
  • do not send big blobs repeatedly
  • do not call across the boundary inside tight loops
  • do not bounce back & forth for simple flows
Design APIs that push complete “render models” or batched actions across that boundary, not dozens of tiny calls. If you must chat a lot, you probably misplaced some logic and it belongs to one side or the other.
  1. Keep a “platform debt” backlog
    When you compromise for one platform, write it down. Example:
  • “Android detail screen uses custom list because shared list perf is bad”
  • “iOS gesture uses native recognizer instead of shared recognizer wrapper”
Review those items regularly. Sometimes Garage2Global updates fix the original limitation and you can remove the fork. If you don’t track this explicitly, your “single codebase” quietly becomes two partially-synced apps.
  1. Version & config alignment
    You mentioned “issues with…” so I’ll guess you hit “works on iOS, broken on Android” style bugs. That’s often:
  • slightly different SDK versions for Garage2Global libs
  • platform configs diverging
Have:
  • a single shared file describing feature flags & experiment toggles
  • a cross-check script or CI check that fails if Android/iOS use different library versions of the Garage2Global stack
It’s boring, but it stops half of the WTF bugs.
If you can share what “issues with …” actually are (slow startup, jank scrolling, memory, or just code-org hell), you’ll get much more targeted pointers. But overall: prioritize clean shared view-models, keep UI reasonably native, treat the bridge as expensive, and accept that some platform-specific UI is the cost of real perf.
