Need help understanding the NHS app and how to use it
I’m confused about how the NHS app works and what I can actually do with it, like viewing medical records, booking appointments, or ordering prescriptions. I’m also unsure how to set it up correctly and link it to my GP practice. Can someone explain the main features, setup steps, and any common issues to watch out for?
Yeah the NHS app confused me at first too, so here is the simple version.
What you use it for
  1. View your details
    • See your NHS number
    • Check your GP practice details
    • Update some contact info
  2. Repeat prescriptions
    • Order repeats from your GP
    • Choose a nominated pharmacy for collection
    • See past medications
  3. GP appointments
    • Book or cancel some routine GP appointments
    • See upcoming appointments
    • Not every practice supports online booking, so your options depend on your GP system
  4. Your records
    This depends on what your GP has switched on. You might see:
    • Test results
    • Consultation notes
    • Allergies and medications
    • Immunisations
    If you see almost nothing, ask your GP reception if “online records access” is enabled for you.
  5. Other stuff
    • View messages from GP or hospital, if they use it
    • Organ donor preferences
    • Organise proxy access for kids or people you care for, through GP
How to set it up and link GP
  1. Download “NHS App” from App Store or Google Play. Not the NHS COVID app.
  2. Open it, choose “Continue with NHS login”.
  3. Enter email and make an NHS login.
  4. Verify your identity. Usually:
    • Take photo of driving licence or passport
    • Take selfie video
    • Answer security questions if asked
    If the auto check fails, you get an option to use “details from your GP surgery” later.
  5. Link to your GP
    If your GP has your correct details, it often links automatically using your NHS number, name, DOB and address.
    If that fails, contact reception and say:
    • “I want online access through NHS app”
    • Ask them to check your mobile number and email
    • They might give you a linkage key or instructions for Patient Access or similar. Keep those.
    Then in the NHS app, go to “Linked profiles” or “GP health record” and follow the prompts.
Common problems
• “No GP practice found”
Your practice might not support the app fully. Ask reception if they support “NHS app and online services”.
• “You do not have access to your records”
Your GP needs to switch this on for your account. You can request “full online record access from [date] onward”.
• Info looks outdated
The app shows what sits in your GP system. If it looks wrong, you fix it by speaking to your surgery, not in the app.
Practical tip
Do this in order and it hurts less:
  1. Check your GP has your correct mobile, email, and address.
  2. Ask them to enable online services and record access for you.
  3. Then set up NHS login and app.
If you say what part you are stuck on, setup, prescriptions, records, people here can walk through that step by step.
Couple of extra angles to add on top of what @suenodelbosque said, since the app can do a bit more than the “GP + prescriptions” basics and some of their steps are more faff than they need to be.
  1. What you actually use it for day to day
    In real life, most people end up using it for:
    • Prescription re-orders
      Not just “repeat prescriptions”. If your GP allows it, you can also:
      • Add a short note with a request when you re-order
      • See which requests are “pending” vs “issued”
        Handy to check if it’s actually been approved before you walk to the pharmacy and stand in a 30‑minute queue behind half the town.
    • Checking what the GP actually wrote
      Once you get records access, it is useful to:
      • Read the GP’s consultation notes after a rushed appointment
      • Check test result comments like “no action required” instead of sitting there refreshing your brain with anxiety
        I don’t agree that you always need to go through reception first. In a lot of areas, records access is now enabled automatically from a certain date onward, you just might not have noticed it.
    • Vaccinations & travel stuff
      You can see your jabs (childhood, covid, flu, etc.). If you travel, this is super useful when some clinic asks, “Are you up to date on tetanus?” and your brain goes offline.
    • Hospital / referral bits
      Depending on your region, you might see:
      • Hospital letters and clinic outcomes
      • Referral status (“referred to x” rather than nothingness)
        It’s patchy, but worth checking the “Messages” and “Hospital” sections occasionally.
  2. Things people expect it to do but it doesn’t (or not well)
    • It is not a magic “see every scan and hospital result ever instantly” tool. A lot of secondary care results only appear in the GP record if they’re copied over.
    • You can’t normally message your GP freely like WhatsApp. Some practices use secure messaging in the app, but most still rely on phone or online forms on their own website.
    • Changing your address / personal details is limited. Often it sends a request to the practice to approve, so do not assume it’s instantly updated.
  3. Setup tips that avoid the common headaches
    I’d actually flip the order that @suenodelbosque suggested:
    • Step 1: Create the NHS login first
      Do the ID photo + selfie bit when you’re not rushed. Use good lighting and hold your ID flat. If it fails, don’t panic, you can usually retry later.
    • Step 2: Once you’re in, check if it already found your GP
      A surprising number of people discover it linked automatically behind the scenes because your NHS number, name and DOB were already matched. Sometimes you don’t need any “linkage key” at all.
    • Step 3: Only then bother your GP reception
      If you can’t see your GP record or prescriptions, then ask reception to:
      • Confirm your mobile / email
      • Turn on “online record access” for you
      • Confirm they actually support the NHS App for booking and prescriptions
        Saves you a trip if it’s already working.
  4. How to sanity check it’s linked correctly
    Simple test list once you’re logged in:
    • Under “GP health record” you should see at least:
      • Your registered practice name
      • Your repeat meds (if you have any)
    • Under “Prescriptions”:
      • A nominated pharmacy
      • A button like “Order a repeat prescription”
    • Under “Appointments”:
      • Either some available slots
      • Or a message basically saying your practice doesn’t offer online booking
        If any of those are totally blank, then it’s a GP-side setup problem, not you doing the app wrong.
  5. When it looks wrong or scary
    • If you see confusing notes (“patient anxious,” “non-compliant,” weird abbreviations) remember this is written in clinician shorthand, not a character judgement.
    • If a result looks “abnormal” in red but your GP said not to worry, check for the text comment. Often the lab range is super strict and the doctor has already reviewed it.
    • You can’t edit your record yourself. You have to query it with the practice if something is truly inaccurate.
  6. Quick mental model so it stops feeling confusing
    Think of the NHS App as a window into whatever your GP practice and NHS services already store.
    • If they switch more stuff on, you see more.
    • If they switch things off, you see less.
    • The app itself is basically a viewer + some basic tools: book, cancel, order, view.
If you say exactly where it’s going wrong for you (for example: “stuck on ID check,” “it won’t find my practice,” “I can log in but see zero records”), people can walk you through that specific bit step by step.
Short version: think of the NHS app as a remote control for your GP record, not the record itself. Your practice decides what you actually see and do.
To complement what @hoshikuzu and @suenodelbosque already covered, I’d focus on three practical angles people usually miss:
  1. What it’s genuinely good at vs not worth stressing over
    Worth using regularly:
    • Sanity‑checking prescriptions: open “Prescriptions,” look for “Issued” vs “Requested.” If it still says “Requested,” your pharmacy will usually have nothing for you.
    • Tracking a new problem: if you have something ongoing (say, new meds or a recent diagnosis), get used to opening “GP health record” after each appointment and reading the latest entry so you know exactly what was agreed.
    • Travel / forms: occupational health, travel clinic, or school forms often ask for immunisation history. Pull it up and screenshot or print.
    Usually not worth the stress:
    • Hunting for every scan or hospital result. Many never make it into the GP system, so if it is not there, you did not do anything wrong in the app.
    • Expecting live chat with your GP. Most practices still rely on phone or web forms on their own site.
  2. Interpreting what you see so it is less alarming
    I slightly disagree with the idea that you should always ask the GP to “fix” wording you dislike. Instead:
    • Treat entries like “anxious,” “non‑compliant,” or “did not attend” as clinical shorthand, not a label on you as a person.
    • Focus on actions: “plan,” “follow up,” “review in X weeks” are the key parts. If those do not match what you remember, that is when to query it.
    • For test results, check three things: numeric value, “flag” (normal / abnormal), and the GP comment. If the comment says “no action,” that is usually more important than the red highlight.
  3. When the app looks empty or half‑broken
    Before going in circles reinstalling:
    • If you can see your name and GP practice but no meds, it may be that you simply do not have repeats set up. You can still ask the GP to convert something you take regularly into a repeat.
    • If appointments and prescriptions sections are present but say they are unavailable, that is a policy choice by your practice. The fix is to ask reception what they support, not to tweak app settings.
    • If absolutely nothing loads under “GP health record,” ask the surgery specifically for “detailed online record access” from a certain date onward. Using that phrase tends to get you further than just saying “NHS app not working.”
Compared to the advice from @hoshikuzu and @suenodelbosque, I’d spend less time worrying about “doing setup in the right order” and more time just logging in, looking at what is actually there, and then using your practice reception to turn missing features on. The app is basically a window. If the view is blank, the problem is usually on the GP system side rather than something you clicked wrong.
Pros of the NHS app:
  • Central place for repeat prescriptions, test results, and vaccination history
  • Saves a lot of phone calls for simple admin
  • Works across different GP systems once access is enabled
Cons of the NHS app:
  • Very inconsistent between practices and regions
  • No real control over what appears or how fast it updates
  • Limited direct messaging and not a full “hospital record viewer”
If you say which category you are in right now (logged in but empty record, stuck at ID, or cannot see prescriptions), people can walk you through that exact snag rather than generic setup steps again.
