Need help setting up my email signature in Outlook
I’ve been trying to create a professional email signature in Outlook, but I’m confused by the settings and can’t get it to show up on new messages or replies correctly. I’d really appreciate clear, step‑by‑step guidance on where to find the signature options, how to format it, and how to make sure it’s applied automatically to all my emails.
Outlook loves to hide this stuff, so here is the clean path.
First, decide which Outlook you use:
• Outlook desktop for Windows or Mac
• Outlook on the web (browser, like Outlook.com or O365)
I will cover both.
Outlook desktop (Windows)
  1. Open Outlook.
  2. Go to File.
  3. Click Options at the bottom.
  4. Go to Mail on the left.
  5. Click the Signatures button on the right.
Now you are in the signature window.
Create the signature:
  1. Under Select signature to edit, click New.
  2. Give it a name like “Work default”.
  3. In Edit signature, type your info, for example:
    Name
    Title
    Company
    Phone
    Website
  4. Use the toolbar to bold your name, add links, change font, etc.
    Example, highlight your website, click the link icon, add the URL.
Make it show on new messages and replies:
  1. On the right, under Choose default signature:
    • Email account, pick your work email.
    • New messages, pick your signature name.
    • Replies/forwards, pick the same signature or a shorter one.
Common gotchas:
• If New messages is set to “(none)” your signature never shows.
• If Replies/forwards is “(none)” you only see it on new emails.
• If you use more than one account, you must set this for each account.
Click OK to save, then OK again to close Options.
Test it:
  1. Click New Email. Your signature should appear at the bottom.
  2. Reply to a message. Check if the reply signature shows.
    If not, Outlook might have reset the defaults, go back and re-check.
Outlook for Mac (new Outlook)
  1. Open Outlook.
  2. Click Outlook in the top menu.
  3. Click Settings.
  4. Under Mail, click Signatures.
Then:
  1. Click the plus icon to add a signature.
  2. Type and format your signature.
  3. Turn on “Automatically include my signature on new messages I compose” and/or on replies and forwards, or assign it to accounts at the bottom.
Outlook on the web (Office 365 or Outlook.com)
  1. Open Outlook in your browser.
  2. Click the gear icon (Settings) top right.
  3. At the bottom of the pane, click “View all Outlook settings”.
  4. Go to Mail, then Compose and reply.
Under Email signature:
  1. Type and format your signature.
  2. Check:
    • “Automatically include my signature on new messages I compose.”
    • “Automatically include my signature on messages I forward or reply to.”
  3. Click Save at the bottom.
Test with a new mail and a reply.
If it still does not show
A few things to check:
• You might be using “New Outlook” vs “Classic Outlook” on Windows.
The New Outlook sometimes syncs signatures from the cloud and ignores local ones.
In that case, go to File, then Options is missing, so use the “Signature” button directly in a new message instead, or manage signatures through your Microsoft account.
• If an admin uses server side signatures, your local one might not apply.
You often see the company format added after sending, not while you type.
• Make sure you are not deleting it by accident when you start typing at the top of the message body. It is easy to over-select text with Ctrl+A and wipe the signature.
Quick checklist:
  1. Signature created.
  2. Set as default for correct account.
  3. New messages set.
  4. Replies/forwards set.
  5. Tested with a new email and a reply.
Do those in order and Outlook stops being annoying about it.
Outlook makes this way more confusing than it needs to be, so on top of what @mikeappsreviewer said, here’s how I usually fix the “my signature exists but never shows up” problem and keep it from breaking again.
I’ll stick to the practical stuff and the weird gotchas instead of repeating the same menu path.
1. First figure out which Outlook is actually running
Microsoft loves renaming things, so:
  • If you’re on Windows and at the top it just says “Outlook” and there’s a toggle somewhere for “New Outlook,” click that and check:
    • Classic Outlook: has File menu with Options.
    • New Outlook: no Options like the old one, signatures are cloud-based.
Why this matters: a signature you set up in Classic does not always show in New Outlook, and vice versa. So make sure you’re editing the one you’re actually using.
Quick test:
Start a new email and look for a Signature button in the toolbar. Click the dropdown.
  • If your signature name appears but isn’t checked / auto inserted, you’re in the right place, just not set as default.
  • If nothing shows, you either:
    • Created it in the other Outlook version, or
    • Created it for a different email account.
2. Check the email account the message is using
This trips people up constantly.
When you click New Email, look right above the message body:
  • There is a From field. That is the account that Outlook is using for that message.
  • Signatures are tied to accounts. If you made the signature for work@company.com but your new message is sending from personal@gmail.com, Outlook will not use your work sig.
Fix:
Create / assign the signature for each account you actually use or force Outlook to always use your work account by default when you click New Email (File > Options > Mail > “Always use the default account when composing new messages”).
3. Replies only: know where Outlook inserts the signature
By default, for replies and forwards, Outlook adds the signature:
  • Above the quoted message,
  • Directly where the cursor starts.
What happens a lot:
  1. You hit Reply.
  2. Cursor is at the top, signature is just under your cursor.
  3. You hit Backspace a few times or Ctrl+A + type, and you wipe out the sig without realizing it.
Quick check:
  • Hit Reply, do nothing, scroll slowly. If you see your info in there before you type, it is working and you’re just nuking it by accident.
  • If it’s not there at all, then yes, your default for replies is probably still set to “none.”
4. For a “professional” signature, keep it from looking like spam
You didn’t ask about design, but this is where people mess up:
Do:
  • Name
  • Title
  • Company
  • Phone (one number is enough)
  • Website
  • Maybe one discreet logo if your company wants it
Avoid:
  • Huge images that turn into attachments
  • 5–10 social icons
  • Three fonts, four colors, quotes, or inspirational nonsense
Outlook especially loves to break complicated, image-heavy signatures when replying to long threads. The simpler the HTML, the more reliably it shows.
5. If it suddenly stops showing up
If it worked once and then dies later, check:
  1. Did an update flip you from “Classic Outlook” to “New Outlook”?
    • If yes, re-create the signature in the new version’s signature editor.
  2. Did your company IT push a server-side signature system?
    • Clue: you do not see your professional sig while typing, but when the message is received it magically has a corporate footer. In that case:
      • Keep your local signature shorter or just your name and number.
  3. Are you using a mobile client sometimes?
    • Mobile Outlook often adds its own signature like “Sent from Outlook for iOS” and doesn’t always sync the desktop signature. That doesn’t break desktop, but it confuses expectations.
6. Quick reset method that fixes most signature weirdness
On Windows desktop:
  1. Open a new email.
  2. Use the Signature dropdown in the ribbon.
  3. Choose Signatures… from that dropdown instead of going through File > Options.
  4. In that window:
    • Create a fresh sig with a simple name like Main.
    • On the right side, explicitly pick:
      • Your correct account under Email account.
      • Main for New messages.
      • Main (or none) for Replies/forwards.
  5. Save, close, restart Outlook.
I disagree slightly with relying only on the global Options route like @mikeappsreviewer described; going in through the New Email → Signature button makes sure you’re editing for the exact message type and account Outlook is actually using.
If you post which exact Outlook (Windows classic / Windows new / Mac / Web) and if you’re using more than one email account, I can walk through the exact clicks and even help you draft a clean-looking signature layout you can paste in.
You’ve already got the “where are the buttons” side covered from @jeff and @mikeappsreviewer. I’d focus on making the signature reliable and clean rather than chasing Outlook’s menus again.
1. Treat signatures like templates, not decorations
Instead of building a fancy block that constantly breaks in replies, keep a core text layout you can reuse anywhere:
  • Full name
  • Role / team
  • Company
  • Direct phone only
  • One main link (site or calendar)
  • Optional: one small logo
Create it once in a simple editor (even Notepad) so it is pure text + basic links. Paste that into Outlook’s editor. This reduces the weird formatting that often stops signatures from appearing correctly in long threads.
Pros of this minimalist approach:
  • Survives copy/paste between Outlook desktop, web, and mobile
  • Less likely to be mangled in plain-text replies
  • Faster to update across all clients
  • Less “branded” look
  • Some companies want legal or marketing blocks that are more complex
2. Use the “two‑signature” strategy
I actually disagree a bit with always assigning the same signature for new messages and replies.
Try this instead:
  • Signature A: Full, polished version for new messages
  • Signature B: Short version (name, role, phone) for replies/forwards
This avoids the “wall of legal text” on every reply and also makes it more obvious when Outlook did not insert the right thing, since the first email and replies will look intentionally different.
3. Let Outlook help you, but do not fully trust it
Treat Outlook’s auto insertion as a default, not a guarantee.
  1. Turn on auto signature for new and reply messages (as described already).
  2. Then, before sending, build the habit of quickly checking the bottom of the message body:
    • If the sig is missing or wrong account, use the Signature dropdown in the message window and manually switch it.
This saves you when Outlook silently decides to use a different account or when a corporate template overrides something.
4. Keep one “master” version outside Outlook
A trick that saves a lot of time:
  • Keep your ideal signature text + layout in a document or note.
  • When Outlook changes (new UI, new PC, new account), just paste and reformat once instead of rebuilding from memory.
Think of that as your email signature in Outlook “product” that you copy into whichever client you use.
Pros of this “external master”:
  • Fast to replicate in Outlook on the web, Mac, Windows, and mobile
  • Easy to edit once and propagate
  • You are not locked into one Outlook version
  • You still have to set defaults per account manually
  • Slight formatting tweaks needed each time
Competitor note:
  • @jeff focused on the straightforward path through settings.
  • @mikeappsreviewer went deeper into weird Outlook variants.
    Both are useful, but combining their navigation steps with a simple, reusable master signature will keep you from fighting the UI again next time Microsoft renames Outlook.
If you share which platform you mainly use (Windows classic, new Outlook, Mac, or web) and whether IT adds a company footer, you can then drop your master layout in and I can help refine the exact wording and structure so it looks professional without bloating every thread.
