Need help setting up Google Voice on my phone and PC
I’m trying to set up Google Voice so I can use one number for work calls and texts on both my phone and computer, but I’m getting confused by the different settings, forwarding options, and verification steps. I’m not sure what I actually need to turn on or link to make sure calls ring on all my devices and voicemail works correctly. Can someone walk me through the proper way to set up Google Voice for everyday use, including any must‑know tips or common mistakes to avoid?
Here is the simple way to set up Google Voice on phone and PC without getting lost in all the menus.
  1. Pick or confirm your Google Voice number
  • On a computer, go to voice.google.com
  • Sign in with the Google account you want for work
  • If it asks you to choose a number, search by city or area code
  • Pick a number, then it will ask for a real phone number to verify
  1. Verify with your real phone number
  • Enter your mobile number when it asks
  • You get a text with a code
  • Type the code on the site
  • This only links the account. It does not mean all calls will forward unless you turn that on
  1. Install the mobile app and sign in
  • On your phone, install the Google Voice app from Play Store or App Store
  • Open it, sign in with the same Google account you used on the website
  • In the app:
    Settings → Make and receive calls
    Choose “Prefer Wi Fi and mobile data”
    That means calls use data through the app, not your normal cell number
  1. Decide what you want Google Voice to do
    You have two basic options:
Option A: Use Voice only inside the apps
  • Calls and texts to the GV number show up in the GV app on phone and on the website on PC
  • Your carrier number stays separate
  • This is simpler for work vs personal
For this, turn OFF forwarding:
  • On computer: Settings → Calls → Forward calls to linked numbers → toggle OFF your mobile number
Option B: Also ring your normal phone number
  • Calls to GV also ring your regular phone like a normal call
  • You answer on the phone dialer, not only in the app
For this, turn ON forwarding:
  • On computer: Settings → Calls → Forward calls to linked numbers → toggle ON your mobile phone
    Note: Texts never forward to your SMS app, they stay inside Voice app or website
  1. Set it up on your PC for calls and texts
  • Use it in the browser: go to voice.google.com
    You see Calls, Messages, Voicemail
  • For better use, install the Google Voice Chrome extension or use the Chrome web app if you like
  • Allow microphone permissions so calls work
  • When a call comes in, your PC rings through the browser, and your phone rings through the GV app
  1. Make your work number show as caller ID
    On computer:
  • Settings → Calls → Outbound caller ID → choose your Google Voice number
On the app:
  • Settings → Calls → Calling preferences
  • Make sure it uses your GV number when placing calls from the app
  1. Clean separation for work
    If you want clear work vs personal:
  • Use the GV app only for work calls and texts
  • Do not give out your real cell number to clients
  • Turn off GV forwarding so you only see work stuff inside the GV app and on the website
  1. Common confusing parts
“Linked number”
  • This is your real phone number used for verification and optional forwarding
  • It does not replace your number
“Carrier vs data calling”
  • If you pick “Prefer Wi Fi and mobile data” in the app, calls go through GV using data
  • If you pick “Use carrier only”, it dials out through your real number and uses a callback method, which is more confusing
Verification fails or loops
  • Make sure that number is not already used for another GV account too many times
  • Log out of other Google accounts in your browser
  • Try again in an incognito browser window
  1. Fast checklist for your setup
Phone:
  • GV app installed
  • Signed in with correct Google account
  • Settings → Make and receive calls → “Prefer Wi Fi and mobile data”
  • Decide if you want forwarding on or off
PC:
  • Signed in to voice.google.com with same account
  • Allowed mic access in the browser
  • Checked caller ID shows GV number
If you tell me:
  • Your country
  • If this is for personal or business use
  • Whether you want calls to ring your normal dialer or only the GV app
I can outline exact settings and screens to tap, step by step, so it matches your use and you do not have to fight with all the menus.
Couple extra angles to add on top of what @techchizkid already laid out, since GV’s menus are… not exactly intuitive.
1. Decide “how” you want to call before touching settings
Ask yourself:
  • Do you want all work stuff 100% inside Google Voice (phone & PC), with your carrier number basically hidden from clients?
  • Or do you want your normal dialer to ring too when the GV number gets a call?
If you want clean work/personal separation, I’d actually avoid turning on forwarding at first, even though the interface keeps trying to push you toward linking & forwarding. Linked number is required for verification, but forwarding is optional. Too many people turn that on and then can’t tell which number people actually called.
2. Caller ID confusion trap
On your phone, test this:
  1. Call someone from the GV app.
  2. Ask them what number shows up.
  3. If they see your cell number, you’ve got the wrong combo of:
    • GV app “Calling preferences”
    • Carrier dialer integration / callback options
I’d keep it simple:
  • In the GV app: use Wi Fi & mobile data.
  • Do not use “Use carrier only” unless you like mystery callback numbers and weird behavior.
3. PC setup tip that saves headaches
On your computer:
  • Stick to one browser for GV and stay signed into only the work Google account there.
  • If you juggle multiple Google accounts, use:
    • A different browser, or
    • A separate profile for your work account.
A ton of “verification loops” and “why is this the wrong number” issues are actually just you being logged into the wrong Google account somewhere. Here I slightly disagree with @techchizkid: incognito helps, but having a dedicated “work browser/profile” is more permanent and less annoying.
4. Notifications: the part that quietly ruins your day
Once GV is working:
  • On phone:
    • Turn on GV notifications for work calls & messages.
    • Maybe turn off missed call / voicemail SMS from your carrier if both are buzzing for the same clients.
  • On PC:
    • Let the browser send notifications, or it’ll feel like it “isn’t working” even though it is.
Do a test where you call your GV number from a friend’s phone:
  • Check what rings: GV app, carrier dialer, PC, or all.
  • Adjust based on what bothers you.
5. Simple “ideal work setup” that usually keeps people sane
Most people wanting your use case end up happiest with:
  • Forwarding OFF
  • GV app on phone, “Prefer Wi Fi and mobile data”
  • Voice in browser on PC, mic & notifications allowed
  • Use only the GV number for clients
That way:
  • Work stuff lives in GV (phone + PC).
  • Personal stuff lives in your normal dialer/SMS.
  • No mystery about which number someone used.
If you reply with:
  • Country
  • iOS or Android
  • Whether you want your normal dialer to ring at all
you can get it dialed in with like 3 exact toggles instead of wandering through every menu GV ever invented.
Couple of extra angles that might clear up the parts that are still confusing, especially the “what is actually ringing” question.
1. Think in “profiles”: Work vs Everything Else
Instead of obsessing over each Google Voice toggle, decide:
  • Work profile
    • Google account used for Google Voice
    • GV number clients see
    • Apps where work rings (GV app on phone, browser tab on PC)
  • Personal profile
    • Carrier number
    • Native Phone / Messages apps
Then make each device obey that split:
On phone
  • Only the GV app is “work.”
  • Native dialer/SMS is “personal.”
On PC
  • Browser profile or separate browser just for the work Google account.
  • Leave personal Google accounts out of that browser to avoid weird verification / wrong-number issues.
I actually think this “account separation first” step is more important than arguing about forwarding on/off like others focused on.
2. Handling forwarding without losing your mind
You basically get three patterns:
  1. No forwarding at all
    • Only the GV app and PC ring.
    • Cleanest separation.
    • You must keep data or Wi‑Fi on.
  2. Forwarding only during certain hours
    • Use GV “Do not disturb” or Focus modes on your phone.
    • Let calls ring your cell during work time, mute later.
    • Good if you sometimes forget to open the GV app.
  3. Forwarding + silent GV app
    • Let calls ring your carrier number only.
    • Use GV only for texting and voicemail management.
    • Not my favorite, because caller ID and “what number did they call” often get confusing.
I slightly disagree with the “forwarding off is always best” idea. For unreliable data or if you are on the move all day, having GV forward to your carrier can save you from missed work calls, as long as you accept the noise.
3. Caller ID sanity check that most people skip
Do this simple test sequence:
  1. From your phone, call a friend from:
    • GV app
    • Native dialer
  2. Ask them which number shows for each.
You want the pattern:
  • GV app → Google Voice number
  • Native dialer → personal carrier number
If that is not what you see, something is misconfigured in “Calling preferences” or you are accidentally using “carrier only” mode in GV.
4. Notification strategy so you do not hate Google Voice
People think Google Voice is broken when it is really just quiet:
  • Turn on sound + banner notifications for GV calls and messages on your phone.
  • Turn off duplicate carrier voicemail or call alerts if they stress you out.
  • On PC, allow sound + notifications in the browser for the work account.
Then call your GV number from another phone and watch:
  • What rings exactly?
  • What pops up on screen?
  • Do you get a missed call / voicemail in both places?
Tweak from there until the behavior matches your mental model.
5. Mapping your ideal use case
For one work number shared between phone and PC, a practical setup:
  • Phone
    • GV app active
    • Data calling preferred
    • Notifications allowed
    • Decide if forwarding is needed based on your signal reliability
  • PC
    • Work-only browser profile
    • Voice open in a pin tab
    • Mic & notifications allowed
  • Behavior
    • All work calls/texts use the Google Voice number
    • Personal calls/texts stay in the native apps
You can treat this like a simple “softphone plus inbox” that follows you between computer and mobile, without trying to merge it with your personal number.
6. On products and tradeoffs
If you are comparing Google Voice to other options for a single work number:
Pros of Google Voice
  • Native integration with your Google account and Gmail.
  • Free or very low cost for basic use in supported countries.
  • Easy text + voicemail + call history in one interface.
  • Works on phone, tablet, and PC without weird extra hardware.
Cons of Google Voice
  • Feature set is limited vs full business phone systems.
  • International support and porting rules can be messy.
  • Caller ID and forwarding options feel confusing at first.
  • Desktop experience is browser‑dependent, no serious desktop app.
Competitors mentioned here already gave strong walk‑throughs:
  • @himmelsjager focused nicely on account separation and notification hygiene.
  • @techchizkid laid out a clean step sequence for initial setup and explained forwarding clearly.
Using their step lists plus the “profiles” idea above should give you a setup that feels predictable instead of random. Once everything is in place, test with a few real calls and texts before giving clients that new number.
