After a recent computer crash, I lost some critical files and am trying to recover them using Easeus Data Recovery Wizard. I don’t have the activation key anymore. Can someone help me with retrieving or finding the key?
Hey, so I get it, losing critical files after a crash is a total nightmare. As far as retrieving your Easeus Data Recovery Wizard key, first thing you should do is check old emails, especially those that contain purchase confirmations or activation details. If you bought the product digitally, Easeus sends a confirmation email with the key.
Next, try logging into the account you used for the original purchase on Easeus’ website. They might have a ‘My Orders’ section where you can find your key. If you still can’t find it, reaching out to Easeus’ customer support with your purchase information (like order number, email, etc.) might help. They can usually retrieve your key.
If you’re hitting dead ends, you might want to consider using an alternative data recovery software. Disk Drill is a solid choice that might help you recover lost files just as effectively. It’s known for being user-friendly and offering a robust set of features for data recovery.
Just in case you’re interested in Disk Drill and looking for ways to save, you can find discount codes on Reddit. Check out this link for Disk Drill Coupon Code on Reddit. It might save you a few bucks!
Hope this helps and good luck with your data recovery!Hey, definitely frustrating when you lose critical files. Sonhadordobosque had some great suggestions, but if you’ve hit a wall with those, I’ve got a few other ideas for you.
Firstly, if you previously saved your Easeus Data Recovery Wizard activation key anywhere on your computer, Windows might have logged that information. There are tools like ProduKey or Product Key Finder that can scan your system for product keys of installed software. It’s a long shot, but worth a try!
Another angle would be to check any cloud backups you might have, such as Google Drive or Dropbox. Sometimes, when I purchase software digitally, I make it a point to save a backup copy of the email, including the key, to the cloud. If you do the same, you might just find what you’re looking for there.
Regarding reaching out to Easeus support, definitely agree with sonhadordobosque, but do remember these customer service inquiries can sometimes take a bit longer than you’d like. In the meantime, you might want to download the trial version of another software, as suggested. Disk Drill is indeed a solid alternative and quite user-friendly. Plus, it doesn’t hurt to have multiple recovery options at your disposal when dealing with lost data.
As for finding discounts or promotions, you could check out Disk Drill Coupon Codes on forums. They often post up-to-date deals that can save you some cash, like this one for Disk Drill Coupon Code on Reddit.
Finally, for those looking for a deal on Easeus Data Recovery Wizard, check out this 58% off Easeus Data Recovery Wizard Coupon. It might improve your odds of recovery while easing the wallet pain a bit.
Good luck, and hope you get those files back!
Try EaseUS’s self-service order lookup. Open the EaseUS account page and sign in with every email address you use. Check “Orders” or “Licenses” for your key.
Also search your inbox for “EaseUS,” “activation,” “license,” “order,” and “reciept.” Check spam and archived mail. Use your bank or PayPal history to find the purchase date and email used.
This route is faster than key-scanning tools and avoids risking your lost files. Do not install recovery software on the damaged drive.
Those product key finders like ProduKey are mostly a waste of time for EaseUS specifically. They pull keys that Windows stores in the registry in a predictable spot, and a lot of third party apps, EaseUS included, don’t keep the license there in plain readable form. You’ll get a long list of Microsoft and driver keys and probably nothing useful. So the suggestion in reply 2 isn’t wrong in theory, it just tends to fail on this exact software.
The bigger question nobody asked: did you actually buy a license, or were you on the trial? Plenty of people install the free version, hit the recovery limit, and only then remember there was supposed to be a key. If you never purchased, there is no key to recover and the email search from @kernelfoxzone won’t turn anything up because it doesn’t exist. Worth being honest with yourself on that before spending an hour digging.
One more trap even if you find the old key. EaseUS licenses are usually tied to a specific major version. If your key was for an older release and you just downloaded the current one, it may refuse to activate. In that case you either grab the matching older installer or you’re back to paying for an upgrade. So finding the key isn’t automatically the finish line.
On the alternatives, @sonhadordobosque and @chasseurdetoiles are right that having a second tool ready makes sense, and Disk Drill is a reasonable first pass since the trial lets you scan and preview what’s recoverable before you pay anything. That preview step is the actually useful part, because it tells you whether your files are even salvageable before you commit money to any license. Just don’t install it, or anything, onto the drive that crashed. That warning in reply 3 is the single most important thing in this whole thread.
If it were me I’d do the boring stuff first: PayPal or card history to confirm the purchase and the email used, then the EaseUS account order page. If that comes up empty, treat it as never purchased and move on rather than fighting the key.
