Need help figuring out how to record on my iPhone
I’m trying to record my screen and audio on my iPhone but I can’t seem to get it to work properly. The options are confusing and I’m not sure if I’m missing a setting or using the wrong feature. Can someone walk me through the right way to record on an iPhone and what settings I should check so I don’t lose important recordings?
First thing to check is if Screen Recording is even turned on in Control Center.
  1. Add Screen Recording to Control Center
    1. Open Settings
    2. Tap Control Center
    3. Under “More Controls” find “Screen Recording”
    4. Tap the green plus so it moves into “Included Controls”
  2. Start a basic screen recording
    1. Go to the screen you want to record
    2. Swipe down from top right corner to open Control Center
    3. Tap the solid circle icon (screen record)
    4. You get a 3 second countdown, then it records
    5. To stop, tap the red pill at the top, or open Control Center and tap the icon again
    6. The video saves to Photos automatically
  3. Turn on microphone audio
    This is the part that confuses most people.
    1. Open Control Center
    2. Press and hold the Screen Recording icon until a small panel pops up
    3. At the bottom, tap the microphone icon so it turns red and says “Microphone On”
    4. Tap “Start Recording” in that panel
    With Mic On, it records:
    • Your screen
    • App sounds
    • Your voice through the mic
  4. If you get no sound from apps
    Check these:
    • Side switch (if your iPhone has one) is not on silent
    • Volume is turned up
    • Focus / Do Not Disturb is off
    • Some apps block internal audio because of DRM, so you only get your voice
  5. If it does not start recording
    • Check if you have enough free storage in Settings > General > iPhone Storage
    • Restart the phone
    • Try turning Screen Time restrictions off:
    Settings > Screen Time > Content & Privacy Restrictions
  6. If you want only your voice, no internal audio
    • Turn down the media volume with the side buttons while recording
    • Leave Mic On so it records your voice only
  7. Quick test to see if it works
    1. Turn Mic On as above
    2. Start recording while on home screen
    3. Say something for 5 seconds
    4. Stop the recording
    5. Open Photos, play the video, check if you hear yourself and click sounds
If you say what part fails, like “no sound at all” or “no mic, only app audio”, people can narrow it down more.
Couple more angles to try that @cacadordeestrelas didn’t really touch, esp. if you’ve followed their steps and it’s still acting weird.
1. Check what kind of audio you actually want
iOS is super picky about this, and it’s easy to get the wrong combo:
  • If you want:
    • Your voice + app sounds → Mic ON, volume up, silent switch OFF
    • Only app sounds (no voice) → Mic OFF, volume up
    • Only your voice (no app sounds) → Mic ON, media volume all the way down
A lot of ppl think “Mic On” magically fixes everything, but if your volume is low or muted, you’ll just get your voice and think the feature is broken.
2. Watch the tiny indicators while recording
When you start recording:
  • The status bar / Dynamic Island should turn red.
  • If you turned the mic on correctly in the long-press menu, you’ll see the small mic icon in the control panel before you close it.
If you don’t see that mic icon lit before you close Control Center, iOS is ignoring your voice and only recording internal audio. It’s super easy to miss and think it “didn’t save” your setting.
3. Some apps just won’t cooperate
This part trips ppl up a ton:
  • Video streaming apps (Netflix, some TV apps, banking apps, etc.) can block:
    • Screen content
    • Or audio
  • Result:
    • Black screen in the recording
    • Or your voice only
    • Or no audio at all from that app
So if your test is in one of those apps, it might never work the way you want. Try with something boring like:
  • Home screen
  • Safari
  • A game that doesn’t use DRM
If it works there, your settings are fine and the app is the problem, not you.
4. Check where it’s saving and how you’re watching it
This sounds dumb, but I’ve seen it:
  • Open Photos > Albums > Recents and find the latest recording.
  • Make sure:
    • Volume is up while playing
    • Your phone isn’t connected to Bluetooth headphones or a speaker in another room
    • “Live Listen” / hearing aids / AirPods aren’t hijacking sound
People sometimes think “no audio recorded” when it’s actually playing off some random device.
5. If the mic keeps flipping off on its own
This can be a thing after updates or if settings got messed up:
  • Go to Settings > Control Center
    • Remove Screen Recording
    • Restart iPhone
    • Add Screen Recording back
  • Then open Control Center, long-press the icon, and turn the mic on again from scratch.
Kind of a mini reset for the control.
6. Quick structured test to figure out what is broken
Do these three short tests:
  1. Mic only
    • Turn Mic On
    • Go to Home screen, don’t open any app
    • Record 5 seconds while talking
    • Stop and play
    • If you hear yourself: Mic works.
  2. Internal audio only
    • Turn Mic Off
    • Open a game or YouTube (in Safari, not the app if possible)
    • Volume up
    • Record 10 seconds
    • Stop and play
    • If you hear the game/video: internal audio works.
  3. Both
    • Turn Mic On
    • Same app, volume up
    • Talk over it for 10 seconds
    • Play it back
    • You should hear both you + app audio.
Tell us which step fails:
  • “No voice in test 1”
  • “No app audio in test 2”
  • “Only one or the other in test 3”
From there it’s way easier to pinpoint: settings vs hardware vs app limitations.
iOS kinda makes a simple thing weirdly confusing, but once you figure out what combo you actually want (mic vs internal vs both), it starts behaving a lot more predictably.
Couple of angles that haven’t been hit yet, especially if you’ve already followed what @yozora and @cacadordeestrelas laid out and it’s still acting odd.
1. Confirm it’s not an audio-route problem
Screen Recording follows whatever your iPhone thinks is the “current” audio output. That can silently break things.
Check these while recording a quick test:
  • Open Control Center and look at the airplay icon (little triangle with circles).
    • If it says a TV, speaker, car, or AirPods, tap it and switch back to iPhone.
  • Turn Bluetooth off for a minute in Settings, not just from Control Center, then record again.
    • This rules out sound going to some speaker in another room.
A lot of “no audio in recordings” is actually “the video is fine, sound is going somewhere else.”
2. Permissions & privacy oddities
iOS can silently block your mic for certain apps or after a privacy reset.
  • Go to Settings > Privacy & Security > Microphone
  • Make sure apps you’re testing with actually have access.
  • If you ever used apps that do voice processing, call recording, or VPN, temporarily disable or delete them, then try again. Some of them hook into audio in strange ways.
If your voice never shows up in any app recording, there might be a general mic or permission issue rather than a Screen Recording problem.
3. Check for Focus / Work Mode rules tied specifically to screen recording
I disagree slightly with the idea that Focus being on is only about silencing notifications. Custom Focus modes can also:
  • Route audio differently
  • Limit apps that can access your microphone
Do this:
  1. Go to Settings > Focus
  2. Open each Focus you use (Work, Driving, etc.)
  3. Look under Apps and Allowed / Silenced Notifications and temporarily disable those Focus modes.
  4. Try recording again with no Focus active at all.
If it only breaks when a specific Focus is on, that mode is the culprit.
4. Test the raw microphone outside Screen Recording
This is to find out if the screen recorder is the problem or the mic hardware/software itself.
Do three ultra-quick checks:
  1. Voice Memos:
    • Record 5 seconds talking.
    • Playback. If you sound clear, mic is healthy.
  2. Camera app (Video mode):
    • Record 5–10 seconds.
    • If the audio is missing or very low but Voice Memos was fine, that points to camera / system AV routing weirdness, which can spill over into Screen Recording.
  3. Phone call or FaceTime (with speakerphone on):
    • Ask the other person if they hear you clearly.
    • If they do, but Screen Recording never catches your voice, then Screen Recording config / software is the likely issue.
5. Storage & background processes
People check storage once, see “a few GB left,” and assume it’s fine. iOS can be pickier:
  • Go to Settings > General > iPhone Storage
  • If you’re under about 2–3 GB free, clean out old videos and photos, then reboot and test again.
Also, force-close any:
  • Third-party screen recorder apps
  • Streaming overlay apps
  • Call recording / game overlay tools
They can compete with iOS’s built-in recorder and cause silent failures or corrupt audio.
6. When recordings are “fine” but sound terrible
If your complaint is more like “it works, but audio is super quiet / echoey / distorted,” that is usually:
  • Mic rubbing against a case or finger blocking the mic hole
  • Very loud in-app sounds overpowering your voice
Tricks:
  • Lower the system volume a bit so your voice is relatively louder.
  • Talk closer to the bottom of the phone where the primary mic is.
  • For long recordings, use wired EarPods with mic if you have them. iOS records that mic too.
7. If nothing fixes it
At that point, what I would do:
  1. Reset all settings (not content):
    • Settings > General > Transfer or Reset iPhone > Reset > Reset All Settings
    • This does not wipe your photos / apps, but it does reset Wi‑Fi, layout, etc.
  2. Test Screen Recording before reinstalling or reconfiguring a bunch of stuff.
If Screen Recording works right after that, it was a software / config issue. If it still fails, you’re looking at a deeper iOS bug or hardware issue, and backup + update / restore through a computer is worth considering.
Last bit: both @yozora and @cacadordeestrelas covered the “how to start” part very well. Where people usually get stuck is not the button presses, but one of these:
  • Audio going to a Bluetooth / AirPlay device
  • App-level blocking (DRM, banking, some streaming)
  • Focus / privacy settings interfering
  • Very low storage causing silent failures
If you can post which combo fails for you (mic only, internal only, or both together) it becomes much easier to pinpoint the exact setting that’s tripping you up.
Try recording through a Mac instead. Connect your iPhone with a cable, open QuickTime Player, then select File, New Movie Recording. Click the arrow beside the record button. Choose your iPhone under Camera and Microphone.
Press Record. QuickTime saves the screen and app audio as a.mov file. For your voice, record narration separately in Voice Memos, then add it in iMovie. This avoids iPhone recording settings entierly.
Think about two people using the exact same mic-on setting: one records a game walkthrough in a quiet room and gets clean narration over the game sounds, the other records the same way with the TV on in the background and ends up with muddy audio where you can barely hear them. Same settings, totally different result. That trips people up because the ‘Microphone’ toggle in Screen Recording isn’t some clean internal voice feed. It’s your actual room mic, so it grabs everything around you, not just your voice.
That’s the piece I don’t see mentioned above. Everyone’s focused on whether the mic is on or off, which is right, but if your complaint is ‘it records but sounds bad,’ the fix usually isn’t a setting at all. Move somewhere quiet, talk close to the bottom of the phone, and drop the media volume a notch so your voice isn’t fighting the app. @boswandelaar touched the case-blocking-the-mic thing and that’s real too.
On the QuickTime route @cyberrouter3323 suggested, it’s solid for clean screen plus app audio, but recording narration separately in Voice Memos and syncing it in iMovie is more work than most people want for a quick clip. If you just need a screen recording with your voice and you’re okay with it not being studio quality, the built-in recorder is fine once the mic icon shows red before you close Control Center. Save the Mac workflow for when audio quality actually matters.
