Need help choosing reliable review management software
I’m trying to find reliable review management software to monitor and respond to customer feedback across Google, Yelp, and social platforms. Right now I’m juggling everything manually, missing some reviews, and it’s hurting our reputation and response times. What tools or platforms are you using, and what features actually make a difference for small to mid-sized businesses?
You’re at the point where you need software, not more tabs.
Short version from what I’ve seen with clients:
  1. Birdeye
    • Good if you have multiple locations.
    • Pulls in Google, Facebook, some others. Yelp is limited because Yelp blocks a lot of direct stuff.
    • Strong for auto review requests by SMS and email.
    • Pricing hits small shops pretty hard. Think a few hundred a month.
    • UI is simple. Staff learns it fast.
  2. Podium
    • Strong for messaging and text reviews.
    • Good central inbox for Google, FB, website chat.
    • Yelp again is tricky, so you still need to log into Yelp sometimes.
    • Great if you want to text customers for payment and reviews in one place.
    • Also not cheap. Fee per location.
  3. Reputation.com
    • Heavy duty. Built more for mid to large brands and franchises.
    • Good analytics. Strong reporting on sentiment and trends.
    • Overkill if you have one or two locations. Setup takes time.
  4. Grade.us / GatherUp
    • Lighter tools. Solid for small to medium businesses.
    • Pull in Google and FB reviews, and send email / SMS requests.
    • Easier on budget than Birdeye or Podium.
    • Interface looks a bit older, but it works.
  5. Sprout Social / Hootsuite
    • Social first. Good for Facebook, Instagram, X.
    • Some review integration, but not as strong as the pure review tools above.
    • Better if your main problem is DMs, comments, and social mentions, not only reviews.
Important stuff to check in demos:
  • Review sources
    Ask exactly which platforms they pull from. Most tools do not fully integrate with Yelp because of Yelp rules. Plan to keep manual checks on Yelp no matter what.
  • Auto alerts
    Make sure you get instant email or mobile alerts for new reviews on Google and FB. That alone saves a lot of headaches.
  • Response from one inbox
    You want to respond to Google and FB inside one dashboard. Test it in the demo. Have the rep show a live screen, not slides.
  • User permissions
    If you have staff, you want user roles for who can reply and who needs approval.
  • Templates
    Look for response templates you can customize. Use them as a base, then edit so you do not sound like a robot.
  • Integrations
    If you use a CRM or POS, ask if they integrate it for automatic review request campaigns after a visit or purchase.
  • Pricing structure
    Ask about per location pricing, per seat pricing, and contract length. A lot of vendors push 12 month contracts. Try to get month to month until you trust it.
Practical setup suggestion:
  • Keep Yelp manual, check it daily or twice a week.
  • Use a review platform that covers Google and Facebook and sends requests.
  • Connect it to your CRM if possible, so every closed job or sale triggers a review invite.
  • Set a simple rule. New review gets a response within 24 hours. Even the 5 star “Great job” ones.
If you share your business type and number of locations, you’ll get more targeted recs. For example, restaurants and healthcare tend to go Birdeye or Podium. Solo service businesses often do better with Grade.us or GatherUp because of cost.
You’re not crazy for feeling buried; once you’re “juggling tabs,” you’re already late to software.
I mostly agree with @himmelsjager, but I’d look at it from a different angle: start with how you work day to day, not just features.
Think in terms of 3 questions first:
  1. How many locations and staff touch reviews?
  2. Is your bigger problem “seeing everything” or “getting more reviews”?
  3. Are you okay being locked into a 12‑month contract?
Once you answer those, the tools sort themselves out.
If your main issue is missing reviews (visibility & alerts)
You want something that excels at centralizing and alerting, not just blasting review requests.
  • Look at tools like Grade.us / GatherUp or Sprout Social if social is big for you.
  • Non‑popular opinion: for a lot of small teams, a lighter tool + a tight internal process beats big suites like Birdeye / Podium that you only use 40% of.
What I’d prioritize for you, in order:
  1. Unified inbox with solid filters
    Not just “everything in one place,” but:
    • Filter by rating (1–3 stars first every morning).
    • Filter by platform.
    • Filter by “unreplied only.”
      That’s what stops you from missing stuff.
  2. Aggressive notifications
    I’d actually disagree a bit with relying only on email alerts like @himmelsjager suggested.
    Email gets buried.
    Look for:
    • Mobile push alerts
    • Slack / Teams integration if you use it
    • Optional daily digest so you can scan yesterday’s reviews at 8am
  3. A response workflow, not just templates
    Templates are nice, but more important is:
    • “Draft” vs “Approved” states if more than one person is involved
    • Internal notes on each review (so you remember what really happened with that customer)
    • Ability to assign a review to a staff member
  4. Yelp reality check
    Every vendor will hand‑wave this in a demo. Ask the rep bluntly:
    • “Do you have official Yelp partnership or are you scraping / email parsing?”
    • “Can I respond to Yelp reviews inside your platform?”
      Most of the time, answer is no, or very limited.
      Plan a simple Yelp habit: 5 minutes every morning in the Yelp app. Done.
  5. Automation that actually fits how you sell
    This is where most people overbuy. They see “integrates with CRM / POS” and sign a big contract.
    Useful scenarios:
    • “Job completed” in your CRM auto‑triggers a review request 2 hours later
    • “No review after 5 days” = one follow‑up reminder
      Useless / risky scenarios:
    • Blasting every contact in your database
    • Auto‑gating (“only send Google link to happy customers”) which can violate TOS
Rough tool direction by situation:
  • 1–2 locations, limited staff, just need to stop missing reviews
    Go light: Grade.us / GatherUp, or even Sprout Social plus a manual Yelp check.
    Key is: one inbox, quick alerts, simple automations.
  • 3–10 locations, multiple people replying, want more reviews + oversight
    Birdeye or Podium start making more sense here.
    I’d lean Podium if texting customers is already a big part of how you operate.
    Lean Birdeye if you care more about location‑by‑location reporting and less about two‑way texting.
  • Single location but high volume / sensitive industry (medical, legal, home services)
    I’d seriously trial both a “big” tool (Podium / Birdeye) and a “lighter” one for 30 days each.
    Sometimes the cheaper one is actually more efficient because it’s less cluttered.
Concrete starter setup that actually works in practice:
  • Pick 1 tool that:
    • Pulls Google + Facebook reviews
    • Has instant notifications and “unreplied reviews” filter
    • Lets you reply in‑app for those two platforms
  • Set a team rule:
    • 1–3 star reviews: responded to within 4 business hours
    • 4–5 star reviews: respond within 24 hours with a short, non‑robotic thank you
  • Yelp:
    • Check the app once per day, same time, every day
    • Turn on native Yelp alerts on your phone
If you drop your business type and number of locations, you can get way more specific recommendations. Right now you’re in that classic “doing too much manually” zone where almost anything will feel like an upgrade, so the danger is overpaying for stuff you won’t touch.
You’re basically at the “pick a system and live in it” stage, not “what’s the flashiest feature set.”
I mostly agree with @nachtschatten and @himmelsjager, but I’d come at it from one extra dimension: how replaceable is this tool if you hate it in 6 months? Because review software lock‑in is real.
Instead of repeating their breakdowns, here are angles they did not emphasize as much:
1. Decide how “single‑pane‑of‑glass” you actually need
Everyone sells “one inbox for everything.” In reality:
  • Google & Facebook: usually solidly covered.
  • Yelp: almost always partial or read‑only at best.
  • Social comments/DMs: better in social tools than in pure review tools.
So ask yourself:
“If I had to leave one tab open all day, which channel would it be?”
  • If it is Google & Facebook, then a classic review platform like Grade.us / GatherUp or Birdeye / Podium makes sense.
  • If it is Instagram DMs, TikTok comments, X mentions, honestly a social suite (Sprout Social, Hootsuite) as the spine plus manual review checks may be saner.
The trap I see: people pay for a big review platform, then still live in the native apps because the social integrations feel shallow.
2. Think in “exit plan” terms before you sign
Here is where I partly disagree with both of them: the obsession with features often ignores data portability.
Before you commit, ask each vendor:
  • “If I leave, how do I export:
    • Review response history
    • Internal notes
    • Assigned owner / status
    • Templates”
If the answer is “CSV with only public review content,” that is a red flag. You will lose a lot of context if you ever move systems.
3. How I would choose in practice
Instead of lining up feature lists, I’d do a 2‑week “sprint” test with 2 vendors side by side, and measure:
  • How many reviews you actually responded to
  • Average response time to 1–3 star reviews
  • How often you had to leave the platform to finish a task
Score them on:
Coverage × Speed × How often I swear at the UI
You will quickly see if a heavy platform like Reputation.com is overkill or if a lean one like Grade.us / GatherUp is enough.
4. About “”: pros & cons in this context
Since you mentioned reliable review management and cross‑platform work, a product like ‘’ (treat it as a typical all‑in‑one review & social feedback hub) fits in the same mental bucket as the mid‑tier tools.
Pros of ‘’
  • Centralized dashboard for Google, Facebook and some social feedback.
  • Good for “I just want one place to see and reply” use cases.
  • Usually simpler to train staff on than enterprise tools.
  • Often more affordable than Birdeye / Podium tier, especially for 1–3 locations.
Cons of ‘’
  • May not give as deep analytics and sentiment tracking as Reputation.com level tools.
  • Yelp support is likely limited or non‑actionable, so you are still doing manual checks.
  • Automation and CRM/POS integrations might be lighter than Podium / Birdeye.
  • If you scale to many locations, role‑based control and advanced reporting might feel thin.
If you trial ‘’, benchmark it directly against something like Grade.us / GatherUp on one side and a heavier tool like Podium on the other. Pick based on how your team moves through the day, not purely on spec sheets.
5. Quick decision shortcuts
To stop overthinking:
  • If you have 1–2 locations and you mostly care about “seeing everything & answering fast”:
    Try ‘’ vs Grade.us / GatherUp. Take whichever lets you handle today’s reviews in the fewest clicks.
  • If you have 3+ locations or multiple staff replying:
    Compare ‘’ vs Birdeye vs Podium and see which one gives the cleanest permission system and reporting. Ignore any feature you did not use in the trial.
  • If social DMs and comments are drowning you more than reviews themselves:
    Prioritize Sprout Social or Hootsuite, keep Yelp manual, and treat any review tool (including ‘’) as secondary.
If you share how many locations you have and roughly how many reviews per week you see now, you can narrow this down to 1–2 tools very quickly.
