Need help choosing between the 5060 Ti and 5070
I’m upgrading my GPU and got stuck deciding between the NVIDIA GeForce RTX 5060 Ti and RTX 5070. I started comparing price, gaming performance, VRAM, and power use, but the more benchmarks I checked, the more confused I got. I need help figuring out which card is the better value for 1440p gaming and long-term use.
If the price gap is small, get the 5070.
Why:
The 5070 is in a different perf tier. In most modern games, you’re looking at roughly 20 to 35 percent more FPS than a 5060 Ti, depending on resolution and ray tracing. At 1440p, that gap matters more. It also gives you more headroom for the next 2 to 3 years.
5060 Ti makes sense if:
You play at 1080p.
You care more about watts and cost.
You found one at a much lower price.
You mostly play esports or older stuff.
5070 makes sense if:
You want 1440p high settings.
You use ray tracing.
You want better 1 percent lows.
You keep GPUs for a while.
VRAM matters too, but don’t stare at the number alone. Bus width, bandwidth, and GPU speed matter too. A weaker card with more VRAM still loses.
My short take:
1080p budget build, 5060 Ti.
1440p build, 5070.
If the 5070 is under like 25 percent more money, I’d pick it easy. If it’s 40 percent more, then nah, the 5060 Ti looks beter on value.
I mostly agree with @shizuka, but I think the real decider is less ‘which card is faster’ and more ‘what are you pairing it with?’
If you’ve got a midrange CPU, 1080p monitor, and you upgrade every 2-ish years, the 5060 Ti is probably the smarter buy. People love chasing the bigger number, but if your setup can’t really stretch the 5070, you’re just paying extra to feel good in benchmark videos lol.
Where I kinda disagree is the price-gap rule being universal. I wouldn’t just say ‘under 25% more = buy 5070’ across the board. If the 5060 Ti model is quiet, cool, and a decent bit cheaper, that can matter more than raw FPS. A lot of AIB pricing is kinda dumb tbh.
My take:
  • 1080p max settings, DLSS, normal RT use: 5060 Ti is fine
  • 1440p ultra, heavier RT, longer upgrade cycle: 5070
  • Small PSU or heat-sensitive case: lean 5060 Ti
  • You hate stutter more than low average FPS: 5070 helps more there
Also check monitor refresh. If you’re on 144Hz 1440p, the 5070 makes more sense. If you’re on 1080p 75Hz, don’t overbuy for no reason. That money might do more for you in a better monitor or bigger SSD tbh.
I’d split it a little differently than @shizuka and the other reply.
The 5070 is not just a “higher settings” card. It’s the better minimum FPS card, and that matters more than average FPS charts. Games feel worse when frametimes get messy, not when the benchmark average drops from 118 to 101. So if you play newer AAA stuff, RT-heavy games, or badly optimized launches, the 5070 usually ages better.
My quick rule:
  • Buy RTX 5060 Ti if value is the goal and you mostly play esports, older AAA, or 1080p/entry 1440p
  • Buy RTX 5070 if you want fewer compromises for the next 3 to 4 years
What I would actually check before buying:
  • Real local price gap, not MSRP
  • VRAM amount on the exact RTX 5060 Ti model
  • PSU headroom and connector situation
  • Whether your current CPU can keep up at 1080p
  • If you use RT, Frame Gen, or high-res texture packs a lot
Pros of the:
  • Lower power draw
  • Usually cooler and easier in smaller cases
  • Better price-to-performance if the gap is big
Cons of the:
  • Less headroom
  • Will hit limits sooner at 1440p ultra and RT
  • Worse resale long term
If the 5070 is only a modest jump in price, I’d lean 5070. If it’s priced stupidly high, the 5060 Ti is the sane pick. The trap is paying “almost 5070 money” for a fancy 5060 Ti cooler.
