I’m trying to change my Facebook name but I keep running into issues with their name rules and review process. I’m not sure what format they accept now or how often I’m allowed to update it. Can someone walk me through the current steps to change a Facebook name without getting it rejected?
Facebook name rules are picky now, so you need to line everything up or their review flags it.
Here is what usually works and what breaks it.
What formats they accept
• Use your real name, same as on ID.
• Allowed: first + last.
Optionally a middle name or middle initial.
• You can add a nickname in the “Other names” section instead of the main name.
• No titles like Dr, Prof, Sir, etc in the name fields.
• No symbols, numbers, random caps, or punctuation in the main name.
• No fake words, phrases, or “funny” names like “Boss Man,” “Your Mom,” etc.
• No doubling of words to look cool, like “John John” unless it is on your ID.
• No business names. For that you need a Page. -
Common things that trigger review or rejection
• Using only one name if your region does not support that.
• Using a nickname as the first name if it is not tied to your ID.
• Using non standard characters.
• Switching to something that looks like a brand or organization.
• Changing from something “normal” to something suspicious in one step. -
How often you can change it
• Once you change the main name, you are locked for 60 days.
• You will still see the option sometimes, but the change will not complete if you are in the 60 day window.
• Facebook stores a history of previous names. Too many weird changes can trigger manual reviews or requests for ID. -
Steps to change it correctly
On the app:
• Open the Facebook app.
• Tap the menu (three lines).
• Tap Settings & privacy, then Settings.
• Tap Personal details or Personal information.
• Tap Name.
• Enter first, middle, last name exactly as on your ID. Standard caps only.
• Tap Review change.
• Pick how you want it shown.
• Enter your password.
• Confirm.On desktop:
• Log in on facebook.com.
• Click your profile picture top right.
• Click Settings & privacy, then Settings.
• In “General” or “Accounts Center,” click Name.
• Enter the name fields.
• Review and confirm with password. -
If they ask for review or ID
• They sometimes ask for an ID photo if the change looks risky.
• Use a clear pic of a government ID, with name and date of birth visible. You can cover the ID number if you want.
• Make sure the name you enter matches the ID spelling and order.
• If you are using a local language spelling, try the official one on your ID first. -
Extra tricks that help
• If your name has accents or non Latin letters, try the “Language specific name” option in settings.
• If you want a nickname like “Jay” or “Jess,” put it as “Other name” instead of main name.
• Avoid switching between fake and real names. That history makes auto review more strict. -
If your change keeps failing
• Try a very “boring” version of your name. First and last only. No middle.
• Remove emojis or symbols from your profile intro and see if the system relaxes a bit on review.
• Log out and back in, then try from a different device or browser.
• If the message says you changed it too recently, you must wait the 60 days. There is no real workaround.
If you want, post the format you are trying, like “Ana María López” or “Jay ‘The Wolf’ Carter,” and people can tell you what part likely breaks their rules.
Couple extra angles to add on top of what @ombrasilente already covered:
- About “real name” vs what actually works
FB says “name on your ID,” but in practice they often accept:
- Shortened first names (Mike vs Michael, Liz vs Elizabeth)
- One middle initial instead of full middle name
- Married vs maiden last name, as long as it looks like a legit human name
Where it usually blows up is when the combo looks fake:
- First name is a nickname + weird last name spelling
- You’re switching from a normal name to something that looks like a joke or a brand in one go
Sometimes it helps to:
- First switch to a very plain, ID-ish version
- After some months, tweak it slightly with a nickname in “Other names” if you really want that visible.
- 60‑day rule is real, but…
Everyone quotes the 60 days, but one thing people miss:
- If FB thinks your current name is violating their policy or “suspicious,” they can force a name review and let you change it again before the 60 days, but only to something that matches your documents.
- If your account ever gets locked and you submit ID, that name often becomes “sticky” and harder to change later without triggering another doc check.
- Region & language quirks
This trips a lot of folks up:
- Some countries allow single names (mononyms), others don’t. If you’re trying to use only one name and your region isn’t one of those, it’ll keep failing.
- For accents and non‑Latin letters, sometimes putting a “plain” Latin version as the main name and then your exact spelling under “language specific name” is more stable.
- Double surnames (like two last names) sometimes get flagged. If your culture uses them, try:
- First name in First Name field
- Both surnames together in Last Name field
- No extra hyphens or random caps.
- Stuff outside the name field that can still trigger flags
Weird one, but I’ve seen this:
- Profile picture with big text like “CEO KING OF SALES”
- Intro/bio full of symbols, brand names, or spammy phrases
- Linking to a business in the name, plus listing yourself as “Owner at [Brand]” everywhere
FB’s system looks at the whole profile vibe. If it thinks “this looks like a brand account,” your name change is more likely to get reviewed or rejected even if the name itself is normal.
- If you keep getting “reviewing your name” forever
A few troubleshooting things that sometimes help:
- Try from a different browser with no extensions, especially no ad‑blockers or VPNs
- Check if your account has any “security alerts” or notifications in Support Inbox and clear those first
- Temporarily turn off VPN or location spoofing; mismatched location vs region settings can make them extra strict
- Make sure your birthday is realistic. Newish account + weird birthdate + name change = instant paranoia from their system.
- When you actually want to match your ID
If you’re tired of fighting it or already hit a wall:
- Decide on the exact spelling/order you want long‑term
- Set your name to that, even if you have to submit ID
- Once FB locks you to that name, don’t keep tinkering with it; too many changes in your history can make future edits a pain.
If you’re comfortable sharing the structure of the name you want (like “two first names, hyphen, nickname in quotes, and double last name”), people can usually tell you which part is tripping the filter without you having to post your full real info.
Short version: your best shot is to make your target name look as “boring human” as possible on the first pass, then tweak around it.
A few angles that haven’t been stressed yet:
Think in “risk levels”
- Low risk: Normal first + last, maybe a single middle initial, standard caps. Most real people fit here.
- Medium risk: Double surnames, accents, common nicknames, transliteration.
- High risk: Quotes, hyphens that are not cultural, obvious brand words, joke words, stylization like xXNameXx.
Move from what you have now toward “low risk” first. After a few months, adjust details (like adding a language‑specific form) instead of jumping straight to a creative format.
Format test without saving
Before you commit, type the name in the change form and see if:- It instantly shows a red warning about invalid characters.
- It silently accepts and goes to “Review change”.
If you get immediate warnings, simplify: - Remove hyphens and quotes.
- Use only standard Latin letters first.
- Cut to first + last only.
Treat nicknames like decorations, not the main structure
Where I slightly disagree with the idea of pushing nicknames too soon: if your account has any previous “weird” names, keep your main name strictly formal for a while. Put the nickname only in:- “Other names”
- Your bio text
- Your profile intro
This gives their system time to “trust” you again before you ask it to juggle a more complex name format.
Time your changes
- Do not try to change your name right after:
- Changing your email or phone
- Logging in from a new country or with a VPN
- Recovering access after a lockout
Do those first, wait a few days of normal use, then attempt the name change. Sudden cluster of security‑type actions plus a name change looks suspicious.
If your culture has unusual structures
Instead of fighting the form fields, adapt them:- Two given names: put them both in “First name” field: “Ana Maria”
- Two surnames: put both in “Last name” field: “García López”
- Very long names: cut to the core that appears on government letters or bank cards, not the full ceremonial version.
If that works, you can later set a “language specific name” with the fully correct spelling.
What to do when it feels stuck in “review”
This is usually a mix of account trust and technical hiccups:- Use a different browser without extensions, and no VPN.
- Clear any alerts in your Support Inbox first.
- Log out of all devices, log in fresh on one device, then try.
If you get the same review loop more than 2 or 3 times, stop trying for a bit. Repeated failed attempts are a negative signal.
Your “endgame” strategy
Decide what FINAL stable name you could live with for a long time, based on:- Matches ID closely enough that you would be okay submitting it.
- Looks obviously like a real person to a stranger.
Get to that version, even if you need an ID check, then stop changing it. Too many past changes reduce your flexibility later.
About the empty product title ‘’: if you ever see name‑change tutorials or tools packaged like a guide or checklist, pros are: everything is in one place, easy to follow, less guesswork. Cons: they cannot override Facebook’s actual rules, and some advice goes out of date quickly if FB tweaks policies.
Competitor perspectives:
- @jeff focused heavily on the policy and edge cases. Good for understanding what is theoretically allowed.
- @ombrasilente added nuance about how FB behaves in practice. Good reality check.
If you want tailored feedback, you can describe the pattern of what you are trying, like “two first names, nickname in quotes in the middle, double last name with a hyphen,” and people can usually pinpoint which element is most likely causing the block without you posting your actual name.
Alternative, simpler path: do a one shot ID verification.
- Set your target name to first last, exactly as on your ID.
- In Accounts Center, Personal details, Name, tap Request change, pick Other.
- Upload a clear photo of a passport or driver license. Add a selfie for match.
- Submit once from the mobile app or Facebook Lite on home wifi. No VPN.
- Align birthday, email, city to your ID adress.
- Use the approved name, then stop edits for a while to let trust rebuild. Expect review to finish faster and recieve fewer flags.
