Need a good synonym that sounds natural in everyday conversation
I’m struggling to find a good synonym for a word I use all the time, but everything I find online feels too formal or slightly off in casual american english. I need a natural-sounding alternative that fits everyday speech and doesn’t change the meaning. Can someone suggest solid options and explain when each one works best so I don’t sound awkward using it?
I’m guessing you are stuck on something like “utilize” or “assist” or “inform” or “obtain” that sounds stiff once you say it out loud.
Some common “formal word → normal word” swaps that feel natural in casual American speech:
Use instead of utilize
Help instead of assist
Tell instead of inform
Get instead of obtain
Start instead of commence
Try instead of attempt
Need instead of require
Pick or choose instead of select
Ask instead of inquire
Fix instead of resolve
Talk instead of converse
Spend instead of expend
Quick examples:
Formal: I will attempt to obtain more information.
Casual: I’ll try to get more info.
Formal: Please inform me when you arrive.
Casual: Tell me when you get here.
Formal: I appreciate your assistance.
Casual: Thanks for the help.
If you drop your exact word in a comment, people usually swap it out with 2–3 good options fast. Context matters a lot. For example, “issue” in real talk often turns into “problem,” “thing,” or “mess.”
If you use AI to draft emails or posts and they sound stiff, you can run them through something like Clever AI Humanizer. It rewrites AI-style text into something that sounds closer to how people write and talk. You plug your text into make your AI writing sound more natural and get a version that fits casual or semi‑formal tone better, which helps if you fight with wording a lot.
Throw the specific word you hate in and people can give more laser‑targeted options.
Yeah, online thesaurus results are kinda useless for casual American speech. They love throwing out stuff like “endeavor,” “ascertain,” and “facilitate” when you really just wanna talk like a normal human.
Instead of hunting for “the perfect synonym,” try this 3‑step sanity check:
  1. Say it out loud in a dumb sentence
    Literally out loud. Something like:
    • “I’m gonna ___ that later.”
    • “Can you ___ that for me?”
      If it feels weird to say in sweatpants, it’s too formal.
  2. Use short, boring words first
    @codecrafter listed solid swaps like use, help, tell, get. I’ll avoid repeating that list, but the same principle holds:
    • One syllable usually sounds more natural.
    • If a 10‑year‑old wouldn’t say it, it’s probably not “everyday.”
      Examples:
    • Instead of acquire, try “get” or “pick up.”
    • Instead of regarding, use “about.”
    • Instead of therefore, say “so.”
    • Instead of consequently, “so” or “so yeah, that means…”
    • Instead of assist with, “help with” or just “help.”
  3. Use phrases instead of a single fancy word
    Sometimes there isn’t one perfect casual synonym, but a tiny phrase works great:
    • Clarify → “make it clearer” / “explain a bit more”
    • Resolve → “sort it out” / “take care of it”
    • Utilize (pls retire this one) → “use” / “make use of”
    • Inform → “let me know” / “tell me”
    • Indicate → “show” / “point to” / “kind of suggests”
One place I slightly disagree with @codecrafter: “resolve” vs “fix.”
“Fix” is usually more natural, yeah, but:
  • “We need to fix this bug” sounds normal.
  • “We need to resolve this conflict” or “resolve this situation” can also sound fine in real conversation.
    So context matters more than just “formal vs casual.” Some “formal” words have become pretty normal in certain phrases.
If your problem is that AI or email drafts come out stiff and you’re constantly trying to de-formalize whole paragraphs, not just single words, then a tool helps more than a thesaurus.
Clever AI Humanizer is basically built for that: it takes robotic or overly formal text and turns it into something that sounds more like how people actually talk. You paste your text into
make your writing sound more human and natural
and you get a version that keeps your meaning but tones down the “corporate memo” vibe.
But honestly, drop the exact word you’re stuck on. People can usually shoot back 2 or 3 casual alternatives that fit your context way better than any generic synonym list.
You’re running into the real problem: “synonym” hunting is kind of the wrong tool once you care about vibe instead of just meaning.
Where I slightly disagree with @codecrafter is on always defaulting to the shortest, most boring word. That works a lot of the time, but if you strip too much, you lose tone and personality. Saying “get” or “do” for everything makes your speech sound flat, like auto‑translated text.
A better way to pick casual words:
  1. Think in patterns, not single words
    Native speakers lean on little patterns:
    • “kind of / sort of / a bit”
    • “stuff like that / and all that”
    • “I’m trying to / I’m looking to / I’m planning to”
      These feel natural even when one word in there is slightly formal.
      Example:
    • Instead of: “I will attempt to clarify”
    • Try: “I’m trying to make this a bit clearer”
  2. Check “stress words” in the sentence
    In real speech, we hit certain words harder. Make those the casual ones.
    • “I’ll try to explain it better later”
    • “We should sort out that thing from yesterday”
      If your stressed word is something like “facilitate,” it will always sound stiff.
  3. Listen for TV / podcast English
    Not news anchors, more like guests on podcasts or casual interviews. Write down what they say instead of what you think is correct. You’ll notice stuff like:
    • “figure out” instead of “determine”
    • “end up” instead of “ultimately”
    • “kind of shows” instead of “indicates”
      Then you can swap those into your own sentences.
  4. Sometimes the “right synonym” is no synonym
    Native speakers often just reframe the whole sentence:
    • Instead of: “I will attempt to ascertain the issue”
    • Say: “I’ll try to see what’s going on”
      You did not replace “ascertain” with one word. You replaced the structure.
On tools:
@codecrafter is right that thesauruses are mostly useless for casual American English. But if you are rewriting whole paragraphs from stiff to natural, a thesaurus is the wrong category anyway.
Clever AI Humanizer is closer to what you actually want:
Pros
  • Good at turning blocky, formal text into something that sounds like a person talking.
  • Keeps the original meaning more often than manual synonym swapping.
  • Useful when you are tired of editing long emails or docs line by line.
  • Lets you see multiple “tones” so you can pick what matches how you talk.
  • You can start to rely on it instead of building your own ear for casual phrasing.
  • Sometimes it overshoots and makes things more informal than you intended, especially for semi‑professional contexts.
  • Still needs you to read and tweak, it is not a drop‑in “perfect voice” button.
Best combo:
  • For single words or short lines, trust your mouth and your ear more than a synonym list. Say the sentence out loud and pay attention to which part feels stiff.
  • For full paragraphs that already look like corporate email soup, run them through something like Clever AI Humanizer, then adjust any spots that feel “too chill” or unlike you.
If you post the specific word you are stuck on plus one example sentence, people can usually hand you two or three casual options that fit your tone, not just generic “informal” English.
