My external hard drive suddenly won’t open in Windows and shows a “parameter is incorrect” error. I’ve read that CHKDSK might fix file system issues, but I’m worried it could make data recovery harder or cause file loss. Should I recover my files first, or is CHKDSK safe to try on this external drive?
I’d treat 'The parameter is incorrect' as a warning sign, not as the actual diagnosis. It can show up when the file system is damaged, the USB connection is flaky, or the drive was disconnected badly after a crash, power loss, or unplugging without ejecting. Windows may refuse to open it even though the files are still there.
The main thing is: don’t write anything to that drive yet. Don’t format it, don’t copy new files onto it, and don’t rush into CHKDSK if you care about the data. CHKDSK can fix some file system problems, but on a damaged drive it can also change, move, or discard broken file system records while trying to repair them.
Start with the simple stuff first:
- Use a different USB cable.
- Plug it directly into another USB port, ideally one on the back of a desktop.
- Try the drive on a different computer.
- Check Disk Management and see if the drive shows up with the correct size.
If Disk Management can still see the drive, even when File Explorer says it’s inaccessible, recovery is still pretty realistic.
For getting the files off, I’d try Disk Drill. It’s useful in cases where Windows can detect the device but can’t read the file system properly.
The safer process would be something like this:
- Install Disk Drill on your internal/system drive, not on the damaged external drive.
- Open it and see whether the external drive appears in the list.
- If the drive disconnects, acts slow, or makes odd noises, make a Byte-to-byte Backup first. That gives you a full image of the drive, so you can scan the image instead of repeatedly stressing the original disk.
- Scan the image if you made one, or scan the original drive only if it seems stable.
- Run a Universal Scan so it can look for readable files, deleted files, and files that can be rebuilt from what’s left of the file system.
- Use the preview before recovering. If photos, documents, or other files preview correctly, that’s usually a good sign.
- Save recovered files to another drive. Never restore them back onto the problem drive. The Windows free version allows up to 100 MB of recovery, which is enough to test whether your files are actually recoverable before paying.
After the important files are copied somewhere safe, then it makes sense to try repairing the drive.
If Windows still sees the file system as NTFS, exFAT, or FAT32, you can run:
chkdsk X: /r
Replace X with the correct drive letter.
If CHKDSK says the drive is RAW or won’t run, I’d look at TestDisk next. It can sometimes rebuild damaged partition information or recover lost partitions without formatting the drive.
If repair tools don’t help and your files are already backed up, a quick format is usually the next thing to try. If the problem was only logical corruption, creating a fresh file system may clear it. But if the same error comes back after formatting, I wouldn’t keep using that drive for anything important. At that point it starts to look more like hardware failure.
Also worth checking, although it’s less common: if you see this same error with other drives or in unrelated Windows tasks, look at your regional settings. Some users have run into this because of an incorrect decimal separator.
If the drive vanishes from Disk Management, clicks, spins up and down over and over, or S.M.A.R.T. data shows a lot of pending or reallocated sectors, stop poking at it. That’s the kind of situation where DIY recovery can make things worse. If the data matters, send it to a recovery lab instead of continuing to power it on.
Do not use CHKDSK as your first test. It is a repair tool, not a recovery tool, and the difference matters here. If the files matter, recover or image the drive first, then experiment with repairs after you have a copy somewhere else. I agree with the caution above, but I’d be extra wary of chkdsk /r on an external drive because it can run for hours and hammer a weak disk the whole time. If you use Disk Drill or any recovery tool, save the recovered files to a different disk, then try CHKDSK or formatting later. If you don’t care about the data, then sure, run CHKDSK and see what happens.
If the drive is physically unstable, meaning it drops out, clicks, spins up again, or takes ages to appear, CHKDSK is the wrong next move no matter which switch you use. I’d only consider a read-only chkdsk X: as a quick sanity check on a drive that stays connected, and I still wouldn’t run /f or /r until the files are copied or imaged. The annoying part is that “parameter is incorrect” sounds like a neat Windows error, but it does not tell you whether the problem is a messy file system or a dying disk. That’s why @stellacadente’s “recover first, repair later” advice is the safer order. CHKDSK may make the drive mount again, but if it “fixes” the directory structure by throwing damaged records into found folders or removing entries, recovery can get uglier afterward.
