How To Use Ai Tools
I keep hearing about all these powerful AI tools for work, study, and content creation, but when I try them I either get generic results or waste time clicking around without a clear workflow. I’m not sure which tools to use for what tasks, or how to prompt them so they give me useful, reliable output. Can anyone explain how you practically use AI tools day to day, which ones you recommend, and any beginner mistakes to avoid so I can finally get real value from them?
I see 3 problems in your post:
  1. Wrong expectations
  2. Wrong tools
  3. No fixed workflow
Here is a simple way to fix it.
  1. Start with 3 tools only
    • Text: ChatGPT, Claude or Gemini
    • Docs / notes: Notion AI or Google Docs AI
    • Images: Midjourney or DALL·E
Ignore everything else for a month. Too many tools wastes your time.
  1. Give better prompts
    Bad prompt: “Help me with my essay on climate change.”
    Better prompt:
    “Act as: writing tutor
    Goal: 1500 word essay on climate change impacts on agriculture in Europe
    Format: outline with headings and bullet points
    Constraints: academic tone, cite 3 real papers with year and author
    Context: this is for a 2nd year undergrad course.”
You want:
• Role
• Goal
• Format
• Constraints
• Context
  1. Lock a workflow for common tasks
Work / study report
Step 1: Outline with the AI
Step 2: Ask it to fill in each section, one by one
Step 3: Paste your sources and say “rewrite using only these sources, keep citations”
Step 4: Final pass “shorten by 30 percent, keep main arguments, make it sound like a 22-year-old student”
Content creation (posts, newsletters, scripts)
Step 1: “Give 10 angles for a post on [topic] for [audience]. Output as table: hook, angle, difficulty.”
Step 2: Pick 1 or 2, say “expand angle 3 into 5-post thread, informal tone, under 240 chars per post.”
Step 3: “Now edit for clarity, remove jargon, keep my voice. Here are 2 samples of my writing: [paste].”
Learning a topic
Step 1: “Explain [topic] for a beginner with no jargon, under 300 words.”
Step 2: “Now create a 7 day plan, 30 minutes per day, with specific tasks and links I can google.”
Step 3: “Give me 5 quiz questions with answers based on day 1 content.”
  1. Use AI as a reviewer more than a writer
    You get better output if you write a rough draft first.
    Then ask:
    • “Point out unclear parts.”
    • “Point out weak arguments and missing data.”
    • “Fix grammar, keep my tone.”
  2. Add data and examples
    When you say “generic results” it is usually because the model has no concrete info.
    Bad: “Write a marketing email for my SaaS.”
    Better:
    • What the product does
    • Who it is for
    • Price
    • One key benefit
    • One key objection
    • Example of a past email you liked
  3. Don’t trust it blindly
    For study or work, always:
    • Ask for sources
    • Verify numbers
    • Search one or two claims yourself
  4. Simple daily routine (20–30 min)
    Day 1: Use AI only to rewrite one thing you already wrote.
    Day 2: Use it for an outline for one task.
    Day 3: Use it for feedback on something you finished.
    Repeat. One use case at a time.
Once you lock a few workflows, the tools stop feeling random and start feeling like a menu of specific “helpers” you call for each step.
You’re not actually missing “more tools,” you’re missing “more structure.”
@cacadordeestrelas gave a solid breakdown of prompts and workflows. I’d tweak the approach a bit, because I think the “start with 3 tools” advice can still be too much if you’re already overwhelmed.
Here’s a different angle: start with one use case, not one tool.
1. Pick a single “AI job” for a week
Examples:
  • “Help me write weekly project updates for my manager”
  • “Turn my messy notes into clean study summaries”
  • “Draft 3 social posts per week from my long article”
For 7 days, use AI only for that job. Ignore everything else, even if TikTok shows you some magic “AI Notion second-brain” thing.
This removes the “what do I use it for?” noise.
2. Use a standing “system prompt” instead of rewriting context every time
Instead of re-explaining your life story in every prompt, create a short “profile” and reuse it.
Example:
“You are my writing and thinking assistant.
I’m a [role: e.g. junior marketer / grad student in econ].
My style: brief, non-formal, no fluff, no inspirational quotes.
I prefer bullet points over paragraphs.
I care about: accuracy first, speed second.
When unsure, ask me one clarifying question before answering.”
Paste this at the top of new chats, then give your actual request below.
This kills a lot of the “generic robot voice” problem.
I actually disagree a bit with the heavy “Act as:” stuff if it turns every prompt into a novel. A tight system prompt you reuse is usually enough, and faster.
3. Work in “loops,” not single prompts
Most people:
“Write my essay.”
“This sucks.”
Close tab.
Try a 3–4 step loop you repeat:
  1. Draft
    • “Give me a rough version of X in 400 words, I will edit it after.”
  2. Critique
    • “Now critique this as if you were my supervisor / professor / client. Short bullets, be harsh.”
  3. Revise
    • “Rewrite it considering your critique. Keep it in my voice: [paste 2 short samples of your real writing].”
  4. Polish
    • “Final pass: cut fluff, keep specifics, no generic advice sentences.”
That loop works for reports, emails, posts, even study notes.
4. Turn your existing apps into “AI on rails”
Instead of chasing “AI tools,” just bolt AI onto what you already use:
  • In Google Docs: write like normal, then
    • “Summarize these 3 pages into 5 bullet points”
    • “Highlight contradictions or unclear parts”
  • In Notion: store your notes, then
    • “Turn these notes into a 10-bullet cheat sheet”
    • “Create 8 flashcards with Q on top, A on bottom”
The key: AI works on your stuff, not from a blank. That alone cuts 70% of the generic output.
5. Create a tiny “AI menu” for yourself
Literally a one-page doc with 5–10 prompts you reuse.
Example categories:
  • Writing
    • “Turn this rough outline into a clear 400-word draft. Keep my tone: [sample].”
  • Shortening
    • “Shorten this by 30 percent, keep all numbers and examples.”
  • Clarifying
    • “Explain this as if to a smart 15-year-old, no jargon.”
  • Studying
    • “Turn this text into a quiz: 10 questions, answers separately.”
  • Brainstorming
    • “List 10 specific ideas for X. Each must include: target audience, format, and one concrete example.”
Copy, tweak, reuse. You don’t need creative prompts every day; you need boring, reliable ones.
6. Calibrate your “AI bullshit radar”
To keep from wasting time:
  • If the answer “feels” generic, ask:
    • “Make this 3 times more concrete. Add numbers, examples, and ‘for instance’ cases.”
  • If you suspect it’s making stuff up:
    • “List which parts of your answer are uncertain or based on assumption.”
  • If you’re studying:
    • “Give me search terms I can use to verify this.”
You’re training yourself to manage the tool, not worship it.
7. When to switch tools (and when not to)
Do not switch tools because:
  • A YouTube video called it “10x”
  • The UI looks shinier
Do consider switching tools if:
  • The model repeatedly refuses or hallucinates in your domain
  • You need a specific feature (long context window, file uploads, etc.)
You’ll get more progress from one tool + 3 stable workflows than from 10 tools with no habits.
TL;DR workflow you can try this week:
  1. Pick one AI job (e.g. “weekly status report”).
  2. Create a system prompt profile and reuse it.
  3. Work in 3–4 step loops: draft → critique → revise → polish.
  4. Feed it your own docs/notes, not blank prompts.
  5. Keep a tiny prompt menu so you’re not reinventing the wheel daily.
Do that for 2–3 weeks and all the “powerful AI tools” hype will turn into “ok, I have 3 very boring but very useful AI assistants that I actually use.”
You’re not missing “secret tools,” you’re missing structure around your own brain. Since @sognonotturno and @cacadordeestrelas already nailed prompts and workflows, I’ll zoom in on the parts they mostly skipped: how you think while using AI and how to avoid becoming a passive button‑clicker.
1. Treat AI like an intern, not a wizard
Both replies focus on what to tell the model. I think the bigger upgrade is how you manage it.
Before every AI session, answer for yourself:
  1. What is the deliverable?
    • “One page brief for my boss”
    • “3 exam‑style answers”
    • “Outline for a YouTube script”
  2. What is the standard?
    • “Good enough to send with light edits”
    • “Rough idea dump only”
    • “Exam answer that scores at least a B”
  3. What is the timebox?
    • “15 minutes max, then I stop”
If you do not set those three, you end up wandering from “generate ideas” to “change tone” to “rewrite again” until the whole thing feels like sludge.
Use AI like an intern:
  • You define the assignment.
  • You define the bar.
  • You decide when to stop.
2. Build a “pre‑AI ritual” so you don’t get generic sludge
Instead of starting in the chat box, start in your own head or notebook for 3 minutes:
  • Write 3 bullets:
    • What I want to say
    • Who it is for
    • What they should do/know after reading
Example for a study summary:
  • I want to say: main theories of motivation
  • Who: me, revising in 3 weeks
  • Outcome: quick recall of definitions + one example per theory
Only then go to AI and say:
“Here are my bullets. Turn them into a structured note with headings, one definition + one real‑world example per item. Keep it under 400 words.”
You’re giving it directional thinking, not just a topic. That reduces the “generic blog post” effect more than any clever prompt template.
3. Use contrast prompts to sharpen quality
One thing I disagree on a bit: just doing “role, goal, format, constraints, context” can still produce very middle‑of‑the‑road stuff if you never introduce contrast.
Try adding comparison:
  • “Give me two versions: one super formal, one very casual, same content.”
  • “Write two outlines: one for beginners, one for advanced readers.”
  • “Show me a weak answer and a strong answer to this exam question, and explain what makes the strong one better.”
Then you can say:
“Take the strong answer style, but reduce the formality by 30 percent and keep my wording where possible.”
Seeing the side‑by‑side examples trains you, not just the model.
4. Build tiny “AI checkpoints” into your real tasks
Instead of thinking “I’m going to use AI for this whole project,” decide specific checkpoints where AI is allowed to help:
For a work report:
  • Checkpoint 1: “Sanity check my outline. What did I miss that a manager might ask about?”
  • Checkpoint 2: “I wrote the intro. Suggest 3 alternative openings that are shorter and more direct.”
  • Checkpoint 3: “Final pass on clarity: highlight any sentence that could confuse a non‑expert, then propose a simpler rewrite.”
For studying:
  • Checkpoint 1: “Turn this page into 8 Q&A flashcards.”
  • Checkpoint 2 (after you answer from memory): “Compare my answers to the text and point out 3 misconceptions.”
This way AI becomes part of a pipeline you already use instead of a separate “AI session” that derails you.
5. Add friction so you don’t become dependent
Nobody really talks about this, but overusing AI kills your own skill development.
Introduce rules like:
  • For writing:
    • First draft = you
    • Second draft = AI feedback
    • Third draft = you again
  • For learning:
    • Try to explain from memory first
    • Only then ask AI to fill gaps and correct errors
  • For ideation:
    • 5 ideas from you, 5 ideas from AI, then mix
If you always let AI start, your brain stops doing the hard parts. That is fine for some admin work, but terrible for actual thinking.
6. Evaluate AI’s answer with a 3‑question filter
Before you accept anything:
  1. Does this actually solve my original problem, or did I move the goalpost?
  2. Which parts are concrete and which are just “advice fluff”?
  3. If I had to bet money, which 2 claims might be wrong or exaggerated?
Then explicitly ask:
“Strip out all generic advice and keep only the concrete, specific parts. Flag any statements that might be uncertain or based on assumptions.”
You become the senior editor. The tool becomes the overconfident junior.
7. Where the blank “product title” fits in
You mentioned “How To Use Ai Tools” as a sort of product title for what you are trying to build for yourself. Treated as a guide or simple internal resource, it has some clear pros and cons.
Pros of “How To Use Ai Tools” as your mini‑playbook:
  • Easy mental handle
    You know exactly what the document is for: your personal handbook for AI workflows.
  • Good for SEO if you ever publish it
    People actually search this phrase, so if you turn your notes into a blog or PDF later, the title is discoverable.
  • Flexible structure
    You can throw in sections on prompts, workflows, pitfalls, and examples without the title feeling wrong.
  • Too generic
    If you keep it only as “How To Use Ai Tools,” you might never specialize it for your use cases, which is where the real value is.
  • Hard to navigate as it grows
    A broad title encourages dumping everything in one place. Better to split into “How I use AI for study,” “How I use AI for work,” etc.
  • Competes with huge generic guides
    If you post it online, it sits next to tons of similar‑titled articles and may get lost without a more specific subtitle.
Practical fix: keep “How To Use Ai Tools” as the top‑level page or doc name, but inside, create 3 short, focused sub‑guides like:
  • “How I use AI for study in 30 minutes a day”
  • “How I use AI for writing at work”
  • “How I use AI for content drafts”
That mirrors what @sognonotturno and @cacadordeestrelas suggested, but makes it your system, not theirs.
8. Quick comparison with the other two replies
  • @sognonotturno focused on: narrow your toolset, prompt structure, and using AI as reviewer. Solid if you like checklists and clear sequences.
  • @cacadordeestrelas pushed: start with one use case, reuse a system prompt, work in loops. Good for people overwhelmed by too many moving parts.
Where I diverge a bit:
  • I’d spend less energy on clever prompt wording and more on defining deliverables, standards, and timeboxes before you even open an AI tab.
  • I’d add explicit “friction rules” so you do not outsource all thinking and end up stuck if tools vanish or change.
If you do nothing else, try this for the next week:
  1. Choose one recurring task (e.g., weekly project update or one course’s notes).
  2. Before using AI, write 3 bullets: what you want to say, who it is for, outcome.
  3. Use AI at 3 checkpoints only: outline check, mid‑draft clarity, final polish.
  4. Keep a living doc titled “How To Use Ai Tools” where you paste only the few prompts and patterns that actually worked for you.
After a month, that doc will be more valuable than any new shiny tool because it encodes your way of thinking with AI, not just generic recipes.
