I just switched from Windows to a Mac and I can’t figure out the right way to take a simple screenshot. I keep pressing random key combos and either nothing happens or I get features I don’t understand, like partial captures or a toolbar. I need a clear explanation of the different screenshot options on macOS and which shortcuts to use for full screen vs a selected area, plus where those screenshots get saved so I can find them later.
Here are the main Mac screenshot shortcuts you want. They all use the Cmd key.
Full screen to a file
Cmd + Shift + 3
This saves a PNG on your Desktop by default. -
Selected area to a file
Cmd + Shift + 4
Your cursor turns into a crosshair.
Click and drag the area.
Release to save to Desktop. -
Window only
Cmd + Shift + 4, then press Space
Cursor turns into a camera.
Move over a window so it highlights.
Click to capture that window. -
Screenshot to clipboard instead of file
Add Control to the combo.
Control + Cmd + Shift + 3 for full screen to clipboard.
Control + Cmd + Shift + 4 for area to clipboard.
Then press Cmd + V in an app to paste. -
Screenshot options panel
Cmd + Shift + 5
This brings up the toolbar at the bottom.
You get options for
– Capture entire screen
– Capture window
– Capture selection
– Record screen (video)
– Choose save location
– Set timer
– Show or hide cursor -
Change where screenshots save
Press Cmd + Shift + 5.
Click “Options”.
Pick Desktop, Documents, Clipboard, etc.
Mac remembers this for the next shots. -
If nothing seems to happen
Look at the Desktop for a new PNG file.
Or check Downloads if you changed settings.
If you see a little thumbnail in the corner, click it to edit. It disappears after a few seconds if you do nothing. -
Quick edit tools
Click that little thumbnail after taking a shot.
You get markup tools, crop, text, arrows.
Then click Done to save, or Share to send.
Takes a bit to retrain your fingers from Print Screen. After a day or two Cmd + Shift + 4 will feel normal.
One thing I’ll push back on a bit from @kakeru: if you’re just coming from Windows, memorizing a bunch of key combos right away can be more annoying than helpful. There is a more “Windows-y” way to handle screenshots on macOS that feels closer to hitting Print Screen and then deciding what to do.
A few tricks that don’t repeat what was already covered:
Use Preview like “Snipping Tool”
- Open Preview (Spotlight: Cmd + Space, type “Preview”).
- Go to the top menu: File → Take Screenshot.
- You get three choices: From Selection, From Window, From Entire Screen.
- It opens straight in Preview where you can crop, annotate, and then save wherever you want.
This is nice if you hate the auto-save-to-Desktop behavior and want more control.
Use the floating thumbnail as a quick “Snip & Edit”
After any screenshot (with those shortcuts @kakeru listed), a small thumbnail pops up at the bottom-right of your screen for a few seconds.- Click that thumbnail.
- You’re in a mini editor: crop, draw, highlight, add text, etc.
- Hit the “Share” button to send directly to Mail, Messages, Notes, etc.
- Or click “Done” to save, or “Delete” if you messed up.
It’s kinda like Windows Snip & Sketch, just Apple-ified and slightly weird at first.
Change the file format & behavior with one-time tweaks
If you don’t like PNGs or want less clutter:- Use Terminal to change format to JPG (smaller files):
defaults write com.apple.screencapture type jpg
then
killall SystemUIServer - You can also kill the little screenshot sound the same way if it bugs you.
This is a one-and-done thing, not something you do every time.
Use Spotlight as your “Print Screen key”
Instead of memorizing all the combos right away:- Press Cmd + Space.
- Type
screenshotand hit Enter.
That opens the same toolbar that Cmd + Shift + 5 brings up, but you don’t have to remember the exact combo while you’re still in “Windows brain” mode.
For super lazy “just need one pic” use QuickTime screen recording
If you ever need a frame from a video or something:- Open QuickTime Player → File → New Screen Recording.
- Record, stop, then use the spacebar in QuickTime to pause on the exact frame you want.
- Then grab a window screenshot of the QuickTime window only.
It’s slower but very precise when you need that exact frame.
Tbh, you’ll probably just use Cmd + Shift + 4 and the floating thumbnail 95% of the time once your fingers stop reaching for Print Screen out of muscle memory. For now, lean on Preview and Spotlight so you’re not constantly trying to remember which weird three-key combo does what.
Skip the key combos for a second and think in “workflow modes.” That’s usually easier coming from Windows.
1. Decide first: do you want files, or just stuff on the clipboard?
- Clipboard-only (closest to Windows Print Screen)
- Hit any normal Mac shortcut, but add Control:
Cmd + Shift + 3 + Ctrl→ whole screen to clipboardCmd + Shift + 4 + Ctrl→ selection to clipboard
- Then just
Cmd + Vinto whatever (Mail, Docs, Slack).
This avoids cluttering your Desktop with random PNGs.
2. Turn the Screenshot toolbar into your “hub”
Yeah, @kakeru and others already mentioned shortcuts, but I disagree that you have to memorize them all right away. Just learn one:
Cmd + Shift + 5
From there:- Pick “Entire screen,” “Window,” or “Selection.”
- Click “Options” and:
- Change save location to a dedicated “Screenshots” folder.
- Toggle “Show Floating Thumbnail.”
- Turn off the sound if it drives you nuts.
Treat this panel as a permanent control center instead of a feature you occasionally trigger.
3. Make a dedicated Screenshots folder so your Desktop does not turn into a landfill
- Create a folder “Screenshots” in your home folder.
- Open Screenshot toolbar (
Cmd + Shift + 5) → Options → “Save to” → “Other Location…” → pick that folder.
Now every tool mentioned by @kakeru or anyone else feeds into the same place. That one change usually makes screenshots feel way more sane.
4. Use stackable tricks instead of new tools
You do not need ten different apps for “How To Ss On A Mac” style tasks. The built in stuff stacks:
- Thumbnail pops up after shot
→ click to mark up, crop, share. - Do not like it?
→ Same Options menu, uncheck “Show Floating Thumbnail.” - Need timed screenshots?
Screenshot toolbar → “Options” → 5 or 10 second timer.
That solves a lot of “I keep capturing the menu closed” problems.
5. Pros & cons of relying on macOS’s built in screenshot system
Pros
- Native, zero installs, works everywhere.
- Markup tools built in: text, arrows, highlights.
- Flexible output: file or clipboard, instant share.
- Customizable location, timer, and format.
- Muscle memory from Windows fights you at first.
- Key combos feel awkward until they “click.”
- Settings are scattered: a bit in Screenshot, a bit in System Settings, a bit via Terminal for nerdy tweaks.
- No always visible “Print Screen” style button.
Compared to what @kakeru laid out, I would say: do not rush to memorize every permutation. Pick one main method (Screenshot toolbar plus Control for clipboard) and let everything else grow from there. Once that feels natural, the advanced shortcuts are just speed upgrades, not essential knowledge on day one.
