How to download audio from YouTube?
I recently watched a great TED Talk on YouTube and I want to download the audio so I can listen to it offline. I’m not tech-savvy and I’m struggling to figure out how to do this. Can anyone recommend an easy way or tool to help me download YouTube audio?
Hey, I totally get the struggle! I’ve been in the same boat wanting to download audio from YouTube for offline listening. What you can do is use a tool like 4K YouTube to MP3. It’s pretty simple and straightforward. You just need to copy the URL of the TED Talk you watched, paste it into the software, and it’ll let you download the audio directly.
You might want to check if the tool has a free version if you’re not looking to spend any cash, but even the paid versions are pretty affordable and make the process a breeze. Just to be on the safe side, always make sure you’re not violating any YouTube terms of service or copyright laws.
Hope this helps!
Alternatively, you might want to give YTMP3 a shot. It’s a web-based service where you don’t need to download any software. Just go to their website, paste the YouTube URL, select ‘MP3’ and hit the button. It’ll convert and let you download the audio. It’s really straightforward.
Worried about finding it? Just pop ‘YTMP3’ into your search engine and it should be right there.
Do be aware of ads and pop-ups on such sites though; they can sometimes be a nuisance.
And yeah, always keep those copyright considerations in mind. Great power, great responsibility and all that.
I understand wanting to keep things simple, especially when tech can get overwhelming. For downloading audio from YouTube, another hassle-free method is using a browser extension like ‘YouTube to MP3’. Extensions seamlessly integrate into your browser, so you just need to hit a download button whenever you’re on a YouTube video. It’s super user-friendly and doesn’t require much technical know-how.
Pros for YouTube to MP3:
  • Easy to use: Just click and download directly from YouTube.
  • Convenient: Integrated right into your browser, no need for extra software.
  • Browser dependency: It only works on the browser you’ve installed it on.
  • Potential security risks: Some browser extensions can be less secure.
What I like about using an extension is the sheer convenience, especially if you’re frequently downloading audio. However, @sterrenkijker’s suggestion of 4K YouTube to MP3 is solid too, particularly if you’re comfortable downloading and installing software. This software typically handles higher quality audio and supports batch downloading—features that can be a big plus if you’re building a collection. The downside is you need to go through the software installation and possible updates.
Comparatively, @shizuka’s recommendation of YTMP3 is great for its no-installation-needed approach. However, web-based services often come with a ton of ads and pop-ups, which can be irritating. Also, there’s always the risk of such sites going down or becoming unreliable.
Another competitor to consider is ClipGrab. It’s a free software available on multiple platforms (Windows, Mac, Linux). Just like 4K YouTube to MP3, you copy-paste the YouTube URL, but ClipGrab also allows some extra options, such as selecting different audio formats and qualities.
In short, if you’re looking for the absolute easiest way, browser extensions and web-based services like YTMP3 are the way to go. If you prefer a more robust and feature-rich solution, software like 4K YouTube to MP3 or ClipGrab might be worth the extra steps. Just keep an eye on those browser ads and remember to respect copyright laws.
Your answer covers extensions, 4K YouTube to MP3, YTMP3, and ClipGrab. Good mix of ease and features. Simpler alternative, use official TED audio. Search the talk on TED.com. Many talk pages show a Download audio link. Click it, save the MP3. If missing, use TED Talks Daily. Open Apple Podcasts or Spotify. Search the talk title. Tap Download. Offline works. Fewer ads, fewer risks for you. YouTube Premium offers offline video in the app. Start the video, lock your phone, you hear audio only. Quick fix for commuting. sory for teh typos.
