How do I add apps to Android Auto?
I’m trying to add some third-party apps like Spotify and WhatsApp to Android Auto, but I’m not sure how to do it. I’ve already connected my phone to my car, but I can’t see the apps I want on the Android Auto interface. Does anyone know how to fix this?
Alright, here’s the thing: Android Auto only shows apps that are compatible with the platform. You can’t just slap anything on there. If Spotify or WhatsApp aren’t showing up, either they’re not installed on your phone or they’re not updated to the latest version. Go to the Google Play Store, check for updates, and make sure the apps are there.
Also, Android Auto doesn’t let you manually add apps. It automatically pulls compatible apps from your phone. If you want to see what’s available, open the Android Auto app on your phone, go to “Customize launcher,” and make sure the apps you want are enabled to show on the car display.
Oh, and some apps are sneaky—they might not appear if you don’t have the right permissions set. Check the app permissions under your phone’s settings and ensure everything’s good there. If all else fails, disconnect, uninstall the Android Auto app, reinstall it, and reconnect to your car. Sometimes you gotta hit the restart button… literally.
Honestly, Android Auto can be a little… stubborn. Look, @viajantedoceu made some good points, but let’s get real here: even when apps are ‘compatible,’ they don’t always play nice with the system. Just because you have Spotify or WhatsApp on your phone doesn’t mean they’ll magically show up. Sometimes, it’s ridiculously dumb stuff like regional restrictions or your phone’s settings screwing things up.
For Spotify, make sure you’re logged into your account properly. Yeah, sounds obvious, but you’d be surprised how often that’s the issue. As for WhatsApp, it might not show up on Android Auto unless you’ve granted it notification access. Check under your phone settings > notifications > special app access. If it’s off, Android Auto will act like it doesn’t exist.
Also, don’t rely on just updates through Google Play – uninstall then reinstall the app entirely. This gives it a nice little shove to reset the connection with Android Auto. And no, you won’t lose your playlists or contacts; it’s not as dramatic as it sounds.
Last thing: are you in developer mode on Android Auto? If not, enable it (tap the version number in the Android Auto settings 10 times like an impatient gamer on ‘God Mode’). Sometimes tweaking those settings, like adjusting the resolution or forcing the desktop app mode, can fix random compatibility blips. If this doesn’t work, I bet the problem’s more with the car system being outdated than your phone. But hey, who likes updating infotainment systems anyway?
Either way, trust me—if things still aren’t showing up, it’s not you. It’s Android Auto.
Alright, so here’s how this whole Android Auto game works—let’s break it down step-by-step style. First off, don’t overthink adding ‘apps,’ because Android Auto doesn’t work like your phone’s app drawer. Instead, it picks and presents ONLY compatible apps already installed on your phone. Forget dreams of manual app installation—ain’t happening.
Steps to Troubleshoot:
  1. Check App Compatibility: Not all apps are made for Android Auto. Spotify and WhatsApp should work, but double-check their compatibility by searching for “optimized for Android Auto” in the Play Store.
  2. Update & Grant Permissions: Just because an app is installed doesn’t mean it’s operational. Update both Spotify/WhatsApp. Then, dig into your app permissions under phone settings—like @viajantedoceu hinted, notification access for WhatsApp is crucial.
  3. Customize the Launcher: Pop into the Android Auto app on your phone, head to ‘Customize launcher,’ and ensure the apps you actually want are toggled on for visibility. If they don’t show in the list, they’re either incompatible, lacking permissions, or seriously moody.
  4. Uninstall/Reinstall Cycle: This sounds redundant, but reinstalling apps like Spotify (don’t worry, your playlists are stored online) sometimes fixes glitches. Same goes for WhatsApp—just redownload it for that fresh sync with Android Auto.
The Quirks:
  • Advanced Developer Mode: While @jeff brought up some cool tweaks like enabling developer settings, I wouldn’t dive in unless you’ve tried everything else. Messing with these settings may fix compatibility or make everything a mess if you’re unfamiliar.
  • Infotainment System Limitations: Android Auto is part phone, part car system. If your car’s head unit firmware is outdated, updates from your phone might not cut it. Unfortunately, updating car software is usually NOT fun and may require dealer assistance.
Pros & Cons of Android Auto:
  • Hands-free functionality for safety.
  • Compatible with major apps like Spotify and WhatsApp.
  • Plug-and-play design (mostly).
  • Limited customization.
  • Sudden app invisibility, as you’ve discovered.
  • Dependent on updated phone/car systems, which can be annoying.
Alternatives:
If Android Auto keeps playing hard-to-get, competitors like Apple CarPlay (iPhone only) and MirrorLink (fewer limitations but less intuitive) may deserve a look, depending on your device and car. Just know Android Auto is one of the better-integrated systems out there—and yes, it comes with its share of stubborn quirks.
Final thought? If none of this fixes the issue, maybe grab a second opinion at an Android Auto forum. No one likes fighting their apps in a moving vehicle!
Try this simpler path.
Forget Android Auto menus for a moment.
On your phone, go to Google Play and install the app “Android Auto Apps Downloader (AAAD)”.
Open AAAD, pick a popular bundle like Fermata Auto or an app pack that includes music and messaging apps.
AAAD installs Android Auto compatible versions for you, no launcher tweaking.
Many users report Spotify like apps showing up right after an AAAD install and reconnect.
Reconnect your phone to the car, wait 10 to 20 seconds, then check the app list again.
