How can I upload images to WordPress using FTP?
I need to upload a bunch of images to my WordPress site, but I want to do it through FTP for speed and convenience. I tried uploading them to the wp-content/uploads folder, but they don’t show up in my Media Library. Is there a way to make WordPress recognize these images or a proper method for uploading images via FTP so they appear in the Media Library too? Appreciate any guidance on this.
How to Get Images into WordPress Using FTP
Alright, so you’re wrangling images and, for whatever reason, WordPress’s built-in uploader just isn’t cutting it. Maybe it keeps timing out, or perhaps you’re dealing with a mountain of pictures and don’t have the patience to drag-and-drop each one. Here’s what I do when I want to toss a bunch of images into WordPress using FTP — raw and unfiltered.
The Gritty Path: FTP and WordPress
Pulling off an image upload via FTP isn’t exactly glamorous, but it’s reliable, especially if you’re dealing with giant ZIPs from a photoshoot or a client dump. Basically, you’re moving files directly into the server’s storage without having to watch a spinny progress wheel crawl across your browser. Here’s the gist:
  • You grab your images and throw ’em into /wp-content/uploads/[year]/[month] (yep, gotta pay attention to the year/month folder structure or WordPress gets grumpy).
  • Once they’re on the server, they don’t just show up in your Media Library like magic (oh, how nice that’d be). You’ll need a plugin like “Add From Server” or poke around with WP-CLI to get WordPress to notice they exist.
Swapping Your FTP Toolbelt
Let me just say: not all FTP apps are created equal. FileZilla’s okay, but if you’re on a Mac and tired of hopping between a million apps to keep your cloud drives and servers in check, CloudMounter works smoothly as one unified hub. If mounting cloud storage as if it were a local drive is your thing, this tool handles FTP, SFTP, and a laundry list of other services. It fits right in with Finder — super handy if you bounce between cloud, FTP, and S3 buckets daily.
Quick & Dirty Walkthrough
  1. Open your FTP client (whatever you like).
  2. Log in to your server. Get those creds from your host.
  3. Navigate down to wp-content/uploads/. Look for folders like 2024/06 or whatever matches your current date.
  4. Drag your images in. Don’t just drop them anywhere — use the right folder, or auto-arranged-galleries will go haywire later.
  5. Let ‘em upload. Might as well grab coffee here, especially with large batches.
  6. Refresh Media Library? Nope. You won’t see them just yet. Use a helper plugin (seriously), or run a scan from the command line if you’re comfy with that.
An Ironic Twist
Uploading via FTP feels a bit retro nowadays, but sometimes, the old ways are the best. It ain’t glamorous, but it gets the job done without fussing over browser compatibility glitches that seem to crop up at the worst times.
TL;DR
  • FTP upload to /wp-content/uploads/
  • Follow year/month folders
  • Media Library needs a nudge to “see” them
  • Tools like CloudMounter keep your file transfers tidy on Mac
If you’ve run into this process — share your war stories or hacks. I’m all ears for awkward tales of permissions errors and duplicate file woes.
Real talk, uploading straight to wp-content/uploads via FTP is fast, but WordPress isn’t exactly “plug-and-play” with files tossed in raw like that. As @mikeappsreviewer pointed out (and yeah, props for bringing up the “Add From Server” plugin), the WordPress Media Library only “knows” about files you upload through the backend or via REST/API calls. That metadata thing is crucial—otherwise, WordPress is just straight-up pretending those images don’t exist.
But here’s where I have to sort of side-eye the whole plugin suggestion spree. Plugins are nice, right, but too many and suddenly your site starts crawling. If you’re only doing this once or twice, fine, grab Add From Server. I’d actually suggest skipping plugins where possible and using WP-CLI for a cleaner solution: wp media import path/to/your/files/* --featured_image will bulk register images and shove ‘em right into your library. Just needs SSH access.
If you’re Mac-based, shoutout to CloudMounter (yeah, same rec as @mikeappsreviewer) for mounting your server like a local drive—beats fighting with FileZilla UI when you’re tired, believe me.
Also: don’t be lazy with the year/month thing. If your images don’t match the folder structure, WordPress can get weird about permalinks down the line.
And, if you find yourself needing this workflow all the time? Consider a real DAM or gallery plugin that can index server uploads. Trying to jam WordPress’s media library into enterprise-level needs is asking for gray hairs.
TL;DR: FTP for upload speed, WP-CLI or plugin for indexing, use the right folders, and don’t let plugin bloat sneak up on you. (Oh, and set server permissions right, or none of this works. Been there, cursed that.)
Short answer: FTP upload is super fast, but WordPress just refuses to care about files that don’t come in thru its front door. Sure, as @mikeappsreviewer and @ombrasilente laid out, you can use the “Add From Server” plugin or some funky WP-CLI voodoo to get the Media Library to see your uploads. But honestly, can we talk about why this process is so clunky in the first place? It feels like WordPress is holding your images hostage unless you jump through all the hoops.
Here’s the thing nobody wants to admit: unless you have a reason to avoid plugins (like an allergic reaction to bloat), just use the plugin for one-offs and nuke it after. If you’re living in the terminal, cool, WP-CLI is slick. But tell me you aren’t at least a tiny bit annoyed that WordPress STILL doesn’t have a built-in “scan for new media” feature?
CloudMounter actually does make dealing with FTP less miserable, especially on Mac. Not gonna hype it up past reason, but mounting your server as a drive so you can drag-drop whole folders? Chef’s kiss.
But also—here’s a hot take—if you find yourself doing this more than once in a blue moon, maybe WordPress just isn’t built for your workflow. DAM platforms exist for a reason. Stop torturing yourself and your site; I don’t care what the tutorials say, the Media Library is not a real asset management system.
If you’re hellbent on FTP, at least script the process, keep track of permissions, and be ready to clean the mess up later. Oh, and don’t trust the year/month folders to be consistent—mixed-case folder names = chaos. Ask me how I know.
