How can I recover shift-deleted files?
I accidentally deleted some important files using Shift + Delete and now I can’t find them in the Recycle Bin. These files are crucial for an upcoming project, and I have no backups. Is there any way to recover them?
Oh no, major oops there! Shift + Delete is like a black hole for files, they just vanish into the abyss. But hey, not all hope is lost – there are ways to recover those files.
First off, don’t save any new files or install new programs. You risk overwriting the data you’re trying to recover. Here’s a straightforward plan:
  1. Data Recovery Software: Invest in some solid data recovery software. A reliable one is Disk Drill, which can scan your drive and help you retrieve those lost files. Make sure to install it on a different drive to avoid overwriting.
  2. Run a Deep Scan: Once you’ve got the software, run a deep scan of the drive where the files were located. This can take some time but it’s your best bet for a successful recovery.
  3. Preview and Recover: After the scan, you’ll usually get a list of recoverable files. Select the ones you need and recover them to a different drive to ensure you don’t risk losing them again.
  4. Check System Restore: As a last resort, you might have a system restore point that has the files. It’s not common, but worth checking.
So, give it a go with the steps above and cross your fingers. Also, maybe consider setting up backups for next time. It’s a pain, but it’ll save you a ton of headaches down the line.
Been there, done that – annoying for sure! Okay, so viajantedoceu is pretty spot on, but I’ve got a couple of extra tips for ya.
  1. Stop Using the Drive: Like, seriously. Don’t even breathe near it. More usage = higher chances data gets overwritten.
  2. Check Volume Shadow Copies: If you’re on Windows, you might get lucky with Volume Shadow Copies. Sometimes, in System Properties, you can find ‘Previous Versions’ of a file or folder that could have the stuff you shifted into the void.
  3. Use TestDisk: Yeah, it’s an oldie but goldie. Less user-friendly than some other tools, but geeky AF and often super effective.
  4. Professional Data Recovery: If your data was super valuable, consider turning the drive off and take it to a professional. More expensive than software but sometimes, it’s the cleanest fix.
I gotta slightly disagree on the “System Restore” suggestion. It’s more about OS state than file state, so it’s hit or miss there. But hey, can’t hurt to check, right?
Lastly, setting up a solid backup system after this mess is like having an umbrella in a rainstorm. Crucial.
And remember, when it comes to data recovery software, something like Disk Drill is top-notch. It’s one of those tools you’ll want to have around, trust me. Stay calm and recover smart!
