I’ve been testing HeyGen AI to create talking avatars for marketing and training videos, but I’m not sure if the avatars look realistic enough for professional use. Some clips look great, others feel a bit uncanny, and I’m worried viewers might notice and be turned off. Can anyone share real-world experiences or an honest review of HeyGen’s avatar quality, realism, and reliability compared to other AI avatar tools?
I’ve used HeyGen for client work for about 6 months, here’s the blunt version.
How realistic are the avatars
• Face: Around 7–8/10 if you pick the better stock avatars and keep scripts simple. Short, clear sentences, no tongue twisters.
• Eyes: This is where the uncanny feel hits. Long monologues or emotional scripts make the eyes look off or “dead”.
• Lipsync: English is solid at normal speed. Fast talk, heavy accents, or technical jargon break it.
• Hands/body: Most avatars are chest‑up, so body language is limited. Good for talking heads, not for dynamic “presenter on stage” style. -
Where it works well
• Internal training videos, SOPs, onboarding. Staff care more about clarity than perfect realism.
• FAQ or support explainer videos. Think 30–90 seconds, simple language.
• A/B test landing page videos. It performs ok visually, and you test message more than face. -
Where it starts to fail
• High‑end brand campaigns. If your brand sells “premium human service”, the slight uncanny effect hurts trust.
• Emotional content. Anything where empathy, humor, or warmth matters looks off. The face does neutral better than emotional.
• Long courses with the same avatar. After 20+ minutes, people start to notice the robotic patterns. -
Tricks to make it look more professional
• Keep clips short. Record multiple 20–40 second segments instead of a 5‑minute block.
• Use quick cuts. Alternate between avatar shots, screen recordings, product shots, slides. Do not stay 100 percent on the avatar.
• Add B‑roll and captions. Viewers then focus on content, not on inspecting the face.
• Write for AI speech. Use shorter sentences, fewer commas, clear phrasing. Avoid “uh, kind of, you know” type lines.
• Match voice to avatar. Some voices look mismatched and break realism fast. Test a few combos.
• Export at higher quality and add slight film grain or sharpening in an editor. It hides some artifacts. -
Where the line is for “professional”
• For internal corporate use, it is already “good enough” if you follow the tips above.
• For paid ads and public facing brand videos, I treat it as a supplement, not a full replacement for real talent. Use it for variants, quick tests, or low‑risk pieces.
• For personal brand content on LinkedIn or YouTube, most audiences still trust a real face more. -
Quick comparison to alternatives
• HeyGen vs Synthesia: Synthesia feels a bit more polished for avatar motion, HeyGen is faster for iteration and has better editing flexibility in my experience. Both still have uncanny moments.
• Real person on camera: Still wins for nuance, expressions, and trust if you put in even basic effort with lighting and a decent mic.
If your clips already look “good sometimes, weird sometimes”, your instincts are right. Treat HeyGen as a tool for speed and scalability, not a full human replacement. For client‑facing or brand‑critical stuff, I still record a human whenever budget and time allow.
You’re not crazy, that “sometimes great, sometimes uncanny” feeling is exactly where HeyGen is at right now.
I mostly agree with @yozora, but a few things I’d frame a bit differently:
“Realistic enough” depends less on the tech and more on how exposed the avatar is.
- If the avatar is on screen full‑frame, talking for 2–3 minutes straight, every micro‑weirdness screams at you.
- If the avatar is one element in a mixed video (screen share, slides, b‑roll, UI demos) it suddenly feels way more acceptable, even for external use.
For marketing, I’d split it like this:
- Top‑of‑funnel ads: I actually wouldn’t use HeyGen as the main face yet. Here I slightly disagree with using it even as a “supplement” on screen. People scroll fast, and anything even slightly uncanny is an instant skip. I’d limit it to variations for voiceover plus product shots, not talking heads.
- Mid‑funnel explainers & product tours: This is where HeyGen can work publicly, not just internally. If your brand is more “practical SaaS” than “premium luxury,” a decent avatar is usually fine. Viewers care way more about “does this solve my problem” than “is this a real person.”
- Test pages & quick campaigns: Honestly, here I think realism is overrated. If you need to spin 10 variations of basically the same video to see which angle converts, HeyGen is gold. The slight weirdness is a tax you pay for speed.
For training content, I’d actually be a bit more bullish than @yozora:
- If you combine HeyGen + clear slides + on‑screen text, you can 100% ship external‑facing client training that feels “professional enough.”
- The trick is to stop treating the avatar like a “virtual instructor” and more like a narrating host that pops in and out. Let the important stuff live on slides and UI, not on their face.
- Long courses: agree that 20+ minutes straight of the same avatar feels robotic, but you can soften that with different angles, scenes, and mixing in screen capture. Doesn’t have to be human-only to feel professional.
A few different things you can try that weren’t mentioned:
- Framing & distance: Don’t always use a tight close‑up. A slightly wider shot makes the facial flaws less noticeable and feels more like a “studio presenter.”
- Lighting & background choice: Pick avatars whose environments match your brand. A hyper‑bright, fake “startup office” background can feel more fake than the face. A neutral, slightly blurred background helps hide the uncanny factor.
- Pacing of speech: Instead of just shorter sentences, try slightly slower delivery. HeyGen mouths tend to look worst when the TTS is racing. If the voice sounds calm and paced, people are less busy micro‑analyzing the lips.
- Layered audio: Soft background music and occasional SFX pull focus away from mouth imperfections. Dead‑silent talking heads invite scrutiny.
- Hybrid with real intros/outros: Record yourself (or a real person) for 10–15 second intro & close, and use HeyGen for the “meat” of the content. Viewers subconsciously grant more trust to the whole video because at least some of it is clearly human.
On the “professional use” question directly:
- If “professional” for you means polished, clear, on-brand, and not embarrassing, then yes, HeyGen is there today as long as you design around its weaknesses.
- If “professional” means “indistinguishable from a real human presenter” for client‑facing flagship stuff, then no, it’s not there yet. Anyone paying real attention will notice something off.
- The bar that actually matters is: do viewers drop off or complain? I’d run a simple A/B test: same script, one with avatar + slides, one with just slides + voice. If performance is similar, the avatar is “good enough,” even if it bothers you as the creator.
So: your mixed results are not a skill issue, that’s just the tech’s current ceiling. Use HeyGen where speed, scale, and clarity matter more than human warmth, and keep real humans for brand-defining pieces where people are evaluating you as much as the content.
Your assessment feels accurate. HeyGen fits explainers, tests, localization, and training where the avatar appears briefly. It still falls short for flagship ads or trust-focused content. Small lip-sync errors become alot more visible in long close-ups.
A simpler option is batch-recording a real presenter. Use a phone, teleprompter app, lapel mic, and one fixed setup. Record 20 short script blocks in an hour. Reuse those clips across videos, then add screen recordings and captions. You get a more profesional result without rebuilding every video from scratch.
Nobody flagged the disclosure risk. If a client or viewer later realizes the confident presenter was an avatar, the trust hit is usually worse than the uncanny face itself, so I’d keep AI avatars off anything where people think they’re watching a real named person. @ghostpanda71’s batch-recording idea sidesteps that entirely, which is why I’d lean that way for client-facing work.
