Do I need a virtual COM port for my device setup?
Trying to connect new hardware that says a virtual COM port might be required. Not sure when or why I’d actually need one or how it works with USB devices. Can anyone explain if and when virtual COM ports are necessary? Any help is appreciated, want to avoid connection issues.
Ever set up a device, only to realize your machine’s missing the hardware to make serial ports work? That’s where Virtual COM ports come into play.
Don’t let the word “virtual” scare you. These ports aren’t just pretty faces—they go all in with supporting every signal line you’d expect from a hardware setup. DTR, RTS, CTS, you name it. Nothing physical to break or accidentally unplug. Those virtual port pairs handle data as if there were real wires involved, making them ideal for emulation, testing, or just not buying more dongles.
If you need a workaround when hardware isn’t an option, or if your gear is somewhere between a museum piece and essential infrastructure, these Virtual COM ports will let you keep things humming without living in the past.
I agree with @mikeappsreviewer that virtual COM ports are like digital stunt doubles for your serial connections, and most apps are none the wiser. But, and here’s where I sometimes disagree—there are cases where you don’t actually need to mess with virtual COM at all. Plenty of new gear talks USB natively and comes with drivers/software that never need a legacy COM port, so double check your manual or support docs. Some manufacturers just toss out “COM port” from force of habit.
If your hardware doesn’t show up in Device Manager as a COM port after you plug it in, or your old app won’t detect it, that’s your cue for something like the Virtual Serial Port Driver (super handy). It lets you create and manage virtual COM ports—your system and software both see these as legit serial ports, making legacy compatibility possible without extra hardware.
For anyone needing to set up a virtual serial connection on your PC, using the right software streamlines everything.
Not to say @nachtschatten and @mikeappsreviewer don’t have good points! They’re spot on about virtual COM ports acting like ghost cables: super clutch for bridging modern machines and legacy apps. If your hardware shows up as “USB Device” in Device Manager, and the software that runs it doesn’t throw a tantrum demanding COM1 or COM2, you’re solid—no virtual port needed.
If you’ve got cranky old control software throwing errors like “No COM port found!” or your device’s installer yells about missing serial connections, THEN you install something like the Virtual Serial Port Driver. It’s especially handy for industrial setups, some barcode scanners, or scientific gear that never moved on from COM port love affairs.
One tip: Don’t just slam a virtual COM setup before you’re sure you need it. Sometimes you can skip a lot of pain by reading two pages further in the manual, or by plugging in the device and seeing what Windows does. If you’re in that weird half-space where a driver auto-installs but nothing shows up as a “COM port,” it’s probably time to consider a solution. In that scenario, using a tool for creating virtual COM ports is quick and keeps ancient software chugging along without even knowing they’re on a USB leash now.
Let’s cut through the COM port cobwebs: Sometimes “virtual COM port required” is legit, and other times it’s leftover tech paranoia from dusty hardware manuals. If you’re working with legacy software screaming for COM1, a virtual COM port is a savior. Need to run data-logging gear from XP-era apps on your USB-only laptop? Then, yeah, tools like Virtual Serial Port Driver are your best friend.
Pros for Virtual Serial Port Driver:
  • Creates unlimited virtual pairs—no hardware needed, instant flexibility.
  • Mimics all handshake/signaling lines, so ornery old apps don’t know the difference.
  • Handy GUI, so you’re not lost in command line land.
  • Sometimes adds an extra layer of software weirdness, which can mess with troubleshooting.
  • Can conflict with certain antivirus/firewall setups.
  • Not always free, so budget accordingly if you just need a quick test.
Colleagues already nailed how these ghost ports slot into place for musty industrial gear. But don’t overthink it: if your device and software just want to chat over new-school USB classes (shows up under “Universal Serial Bus controllers” or “Other Devices” in Device Manager), a virtual COM port might be pointless. No sense plugging in another driver if your stuff works out of the box.
Competitors in the thread pointed out solid use cases—factories, scientific gadgets, barcode readers—but for your average USB gadget, just try installing what you got, and see if it talks. If it’s silent, that’s your cue to try Virtual Serial Port Driver (or similar). Don’t get COM-port anxiety unless the software literally yells at you about a missing port.
One extra tip: some USB devices install their own virtual COM driver automatically. If you see a numbered COM port show up after plugging it in, you’re already good. Only get manual when there’s nothing there and your software starts throwing serial shade.
