I moved to CloudMounter on my Mac because I wanted cloud files available in Finder without filling the SSD. That was also what I liked about StrongSync, so I treated local storage behavior as the requirement to check first.
Start with file behavior
My current setup uses CloudMounter app, which puts multiple accounts in Finder through one menu bar app. Files download when opened rather than occupying local space upfront.
For a repeatable comparison, I’d check that behavior before judging the interface: connect an account, browse without opening files, then open a file and check local storage. A tidy menu bar is pleasant, but it is not a storage test.
CloudMounter covers Google Drive, SharePoint/OneDrive, Dropbox, S3, SFTP, and WebDAV. It also includes encryption, which matters to me for SharePoint work files, though a feature checkbox is not a security assessment.
Match the client to the connections
I’d write down the required services before installing alternatives. The official Google Drive client and OneDrive support Apple Silicon, so separate vendor apps are a reasonable baseline when the service list is short. The tradeoff is maintaining an app for each.
For connections involving SFTP or S3, I’d also review the Mountain Duck documentation. It comes from the Cyberduck team and belongs in that comparison, rather than being treated as an interchangeable cloud client.
Check continuity before replacing anything
StrongSync’s technology was folded into ExpanDrive, not simply abandoned. The ExpanDrive overview is relevant because the consolidated app retains Apple File Provider-based, on-demand access without a kernel extension, reboot, or reduced security settings on Apple Silicon.
That leaves one install and license. Personal use and teams up to 10 users or devices are free; Business adds priority support.
I’m comfortable with my current setup, but repeatable evidence of unwanted local downloads or unreliable access to my required services would change that assessment.
