My current headset has started losing charge halfway through my usual evening session, and the face padding is worn enough that I keep adjusting it. Last night I spent 17 minutes clearing space and checking settings before giving up.
For Meta Connect 2026, are you mainly hoping for new hardware, software improvements, or better apps, and would you hold off replacing a worn headset until the announcements?
Don’t keep pushing a headset with a failing battery if it starts getting unusually hot, swelling, or shutting down unpredictably. Waiting for an announcement is not worth turning a worn device into a safety problem.
My main hope is software that gets me into VR faster. Better room detection, settings that stay saved, fewer account prompts, and reliable wake-from-standby would matter more than another resolution bump. Spending a chunk of an evening clearing space and troubleshooting is exactly the kind of friction Meta needs to fix.
On hardware, I’d want longer real-world battery life, a more comfortable stock strap, and padding that can be removed and cleaned without becoming loose. Better apps come third for me. The library needs more substantial releases, but even great games get ignored when using the headset feels like prep work.
I’d hold off replacing it until Connect only if the event is close and the headset is still safe and usable. A replacement facial interface or external battery may buy some time for much less money. If every session is being cut short or abandoned, though, I’d replace it rather than spend weeks waiting for hardware that might be announced without shipping right away.
An announcement is not the same as hardware you can buy that week. My real wish is a headset built around replaceable wear parts: an accessible battery, a facial interface that stays secure after repeated cleaning, and straps that swap without awkward adapters. Better specs mean little if normal aging turns the whole device into e-waste.
The hidden cost of a new headset is usually the pile of accessories that no longer fits it. A replacement headset sounds appealing until the strap, prescription inserts, charging dock, facial interface, and battery pack all need replacing too. That can turn a modest upgrade into a much larger purchase.
So my most wanted Connect announcement is a clear compatibility plan. Keep the mounting points consistent, carry controllers and common accessories forward where possible, and publish the dimensions before launch. If Meta changes the design, offer an inexpensive adapter instead of making everyone start over. I agree with @reveurdenuit that wear parts should be replaceable, but standardizing those parts across generations would be even more useful than making them removable on a single model.
For the headset itself, I would take lower weight and better balance over more graphics power. Battery life gets the attention because it is easy to compare, but a lighter front end can make the same session feel much less tiring. A larger battery that adds more pressure to your cheeks is not automatically an improvement. I would rather see efficient hardware, a balanced stock strap, and straightforward support for an external battery when a longer session calls for it.
Meta should announce a real upgrade route too. A trade-in program, a guaranteed period of security updates, and a firm date for when major apps may stop supporting older hardware would make the decision much easier. Phone and console buyers usually have some idea how long their device will remain useful. VR buyers are often left guessing whether an aging headset is merely uncomfortable or already near the end of meaningful support.
The announcement I do not want is a vague prototype with no price and no shipping window. Give people a finished product, the total cost of the normal accessories, and a date they can actually order it. In your situation, that information would be more valuable than a flashy demo because it tells you whether waiting saves money or just leaves you wrestling with worn padding for another few months.
A bigger battery is the wrong fix.
What I want from Connect is proper power management: a charge limit, a readable battery-health estimate, and a true wired-power mode that stops constantly cycling the internal cell during longer sessions. An external pack can extend play time, but it can also add weight and hide the fact that the original battery is wearing out. If the headset still depends on that tired internal cell to regulate everything, plugging in another battery only postpones the same problem.
That is why I agree with @binary_optic_wizard on keeping the headset light. Meta could advertise another hour of runtime by stuffing in a larger battery, then leave users with more pressure on their face and more heat trapped around the hardware. Better efficiency would help every session without imposing that penalty. I would happily trade a small performance increase for cooler operation, predictable standby drain, and an option to cap charging below full when the headset spends most of its life on a dock.
I would want battery condition exposed in the settings too. Phones and laptops can give you some warning that a battery has aged. With a headset, users often have to guess whether shorter sessions come from the battery, a background process, a bad cable, or a recent update. A simple health percentage and a session power-use breakdown would make replacement decisions much less frustrating.
For your current headset, fresh padding could solve the constant readjusting, but I would not buy a pile of accessories just to drag it through another product cycle. If Connect announces hardware, wait for details on heat, charging behavior, and sustained battery performance rather than accepting the headline runtime. Those are the details that determine whether the new headset still feels good after the launch excitement wears off.
Buying a headset at launch and buying the outgoing model the week it gets discounted are two very different bets, and I think most of this thread is quietly assuming the first one. The second one usually wins on cost. Every time Meta puts a new headset on stage, the previous generation drops in price and floods the used market. If your evening sessions are getting cut short, grabbing last year’s model cheap right after Connect might fix your problem for a fraction of what the shiny new thing costs, minus the wait for it to actually ship.
On the replaceable wear parts hope from @reveurdenuit, I want that too, but I’d keep expectations low. Meta doesn’t really make money on the hardware. The whole point of selling headsets near cost is to get you into the store and the ads. A device you can keep alive for six years with a fresh battery and new padding is not the outcome that helps their numbers. So I’d love a repair-friendly design, but I’m not planning my next purchase around it.
@digitalbear6945 is right that battery health should be visible, and honestly that’s the one software ask I’d actually bet on happening, because it’s cheap for them to add and makes upgrade nudges look helpful instead of pushy.
The thing nobody’s mentioned is resale timing. If you’re going to replace, sell or trade your current one before the announcement, not after. The moment new hardware is official, the value of what you’re holding drops, and a worn battery drops it further. Waiting weeks to see a demo can quietly cost you whatever your old headset would have fetched today.
For right now, a new facial interface is worth it just to stop the constant readjusting, since that’s a comfort fix you’ll notice every session regardless of what gets announced. I wouldn’t sink money into a new strap or dock on top of it though. Fix the one annoyance, watch what drops in price after the event, and don’t get talked into the launch model just because it’s on stage.
Migration needs to stop being a project.
My Connect wish is a real device-to-device transfer that carries over saves, Wi-Fi credentials, controller mappings, accessibility settings, profiles, and installed apps without rebuilding everything by hand. Hardware upgrades feel much less appealing when “setup” means an evening of downloads, logins, and checking whether every game actually synced.
I’d be cautious about @turbothinker1248’s sell-before-the-event strategy for that reason. A lower resale value may hurt, but being stuck without a headset while announced hardware waits for release is worse. Give buyers a firm shipping date and a painless migration path, then the replacement decision becomes much simpler.
If your sessions are already getting cut off mid-evening, none of the wait-for-Connect math applies to you, so stop treating an announcement like it’s part of the decision. Fresh padding fixes the readjusting now, and I’d honestly ignore @turbothinker1248’s sell-first idea until you’ve actually got a replacement in hand, because going dark between hardware isn’t worth a few saved bucks.
