Has anyone used Mountain Duck for over a year?
I often find these apps work great for the first week then start getting glitchy. I’d love to hear from someone who has used it long-term—does the performance hold up, or does it get sluggish over time?
Quick Take - What Mountain Duck Actually Does
I’ve used Mountain Duck as a way to mount cloud storage and remote servers directly into Finder, and the core idea is pretty simple - it turns remote storage into something that behaves like a local drive.
Instead of juggling multiple apps for Dropbox, Google Drive, SFTP servers, etc., you just mount them and access everything in one place. In my experience, that convenience is the main reason people try it in the first place, and it generally delivers on that promise - with a few caveats depending on how heavy your usage is.
The Good - Where It Works Well
What I noticed pretty quickly - and what a lot of people seem to mention - is how much it simplifies working across different storage services. Instead of opening separate clients, everything shows up in Finder or File Explorer, which just feels more natural.
It supports a wide range of protocols and services - FTP, SFTP, WebDAV, SMB, plus cloud platforms like Amazon S3, Google Drive, Dropbox, and OneDrive. That flexibility is a big deal if you’re working across different environments or managing multiple accounts.
The “smart sync” approach is also something I found useful. Files stay remote until you actually open them, and then they get cached locally. That means you’re not forced to download entire directories upfront, which helps if you’re dealing with limited disk space or large datasets.
Finder integration is another strong point. You can use context menus, open files directly in apps, and generally treat remote files like local ones. It doesn’t feel like a workaround - it feels built into the system, which makes everyday tasks smoother.
One thing I didn’t expect to use much but ended up appreciating is the built-in Cryptomator integration. It handles encryption on the fly, so files are protected before they even hit the cloud. A lot of users highlight this as a major plus, especially if they’re working with sensitive data.
Also worth mentioning - it’s actively maintained. Updates come fairly regularly, and bugs do get addressed over time, which gives some confidence that it’s not abandoned software.
The Not-So-Great Part - Where It Struggles
One real snag some people hit is performance with large file collections, and I’ve definitely seen this myself.
It works fine when you’re dealing with smaller folders, but once you connect to something bigger - hundreds or thousands of files - things can slow down noticeably. Browsing directories takes longer, and sometimes Finder feels like it’s waiting for Mountain Duck to respond.
For example, when I tried navigating a large archive of images, just opening folders became a bit of a waiting game. It’s not broken, but it does feel sluggish enough to interrupt your workflow.
There’s also a bit of a learning curve. Setting up connections, understanding caching behavior, and managing different protocols isn’t always intuitive at first. It’s not overly complex, but it’s not plug-and-play either.
Resource usage is another thing to keep in mind. On macOS especially, I noticed it using a fair amount of memory when multiple mounts were active. It didn’t crash anything, but it’s something you feel if your system is already under load.
And then there’s the upgrade model. Major version updates aren’t free, which some users find frustrating, especially if you’re expecting long-term updates after purchasing.
Worth Knowing About - Alternatives to Consider
If you’re comparing options, CloudMounter comes up pretty often as a similar tool.
It takes a comparable approach - mounting cloud storage as local drives - but focuses a bit more on ease of use and performance in some cases.
Some of the things it offers:
  • Support for Amazon S3, Dropbox, Microsoft OneDrive, Google Drive, and MEGA
  • Simple login process - connect and access files directly from Finder
  • Built-in encryption that secures files before upload and decrypts them automatically
  • Works on both macOS and Windows with similar functionality
  • Offline mode, so you can work without a connection and sync later
What stands out - based on my experience and what others mention - is that it tends to handle large file collections more smoothly than Mountain Duck. The slowdown issue doesn’t hit as hard in those scenarios.
There are trade-offs, though. Pricing, feature depth, and how each tool handles protocols can differ, so it really depends on your workflow.
Other alternatives like rclone and ExpanDrive also come up. rclone is powerful but command-line focused, while ExpanDrive is more similar in concept but has mixed feedback on reliability.
Bottom Line - Is It Worth Using?
So if you’re asking whether Mountain Duck is worth it - I’d say it depends on how you plan to use it.
If your goal is to simplify access to multiple cloud services and work with files directly from Finder or File Explorer, it does that reasonably well. The flexibility, protocol support, and encryption features make it a solid option for a lot of setups.
But if your workflow involves constantly navigating large, complex folder structures, the performance slowdown can become a real frustration over time.
What I’ve noticed - and what others seem to echo - is that it works well for lighter or moderate use, but starts to struggle as things scale up. It’s still a useful tool, just one where your specific use case makes a big difference.
I ran Mountain Duck for about 18 months on macOS with S3, WebDAV, and one SFTP box.
My take is simple. It stayed stable enough if I treated it like mounted remote storage, not like a full sync app. That difference matters a lot.
What held up over time:
  1. Finder integration stayed solid.
  2. Reconnects after sleep were decent.
  3. Small docs, PDFs, code files, and routine edits worked fine.
  4. Cryptomator support was useful.
What got old:
  1. Large folders felt slow. 5,000 plus files was where I started to get annoyed.
  2. Cache weirdness showed up a few times after bad wifi. Not data loss for me, but stale file views and re-open issues.
  3. Office files over flaky connections were hit or miss.
  4. Memory use climbed with multiple mounts.
I slightly disagree with @mikeappsreviewer on one point. For me it was not only a ‘scale’ issue. Network quality mattered as much as folder size. On fast wired internet, Mountain Duck felt fine. On hotel wifi, it felt rough and kinda janky.
If your long term use is light editing and file access, it’s fine. If your workflow depends on big media libraries or lots of random folder browsing, I would test CloudMounter too. I found CloudMounter smoother for cloud drive style use, while Mountain Duck felt stronger for mixed server protocols.
Short version. Good tool. Not a set-and-forget miracle. Test your exact storage setup for a week or two befor you commit.
I used Mountain Duck a little over 2 years on Windows at work and mac at home, mostly for SFTP, Backblaze B2, and OneDrive. My experience sits somewhere between what @mikeappsreviewer and @chasseurdetoiles said, but I’m a bit less forgiving about the “it’s fine if you know its limits” angle.
For long term use, it was dependable enough, but not invisible. That matters. The best file tools disappear into your workflow. Mountain Duck never fully did that for me.
The good:
  • mounts stayed available most of the time
  • updates did improve some annoyng bugs
  • great if you need lots of protocol support in one app
  • better for server access than for pretending cloud storage is truly local
The bad:
  • random pauses in folder listing never really went away
  • thumbnail-heavy folders could get painful
  • if the connection blipped, sometimes I had to remount or clear up stale behavior
  • not something I’d trust for constant live editing of important docs over unstable internet
So my honest answer: yes, it can work long term, but only if your expectations are realistic. I think people get burned when they expect Dropbox-style smoothness from something that is really more of a mounted network layer.
If your use is remote server access first, Mountain Duck is solid enough. If your use is cloud storage as a daily working drive, I’d also test CloudMounter before locking in. In my setup, CloudMounter felt less fussy for that specific job. Not magic either, just less friction day to day.
