Can I Connect My Doro Phone to a Mac?
I’m trying to figure out how to connect it to my Mac. On the Doro website, they mention that Android File Transfer can be used for this. Has anyone actually tried it? Is it reliable, or does it freeze up and cause problems like I’ve heard about with some Android phones?
I also came across MacDroid while searching for other options. It looks like it does the same kind of file transfer, but from what I’ve read it seems more stable. I’d love to hear about real experiences before I pick a method.
You can connect a Doro phone to a Mac, but the original Android File Transfer app from Google is no longer supported. Doro offers its own version on its website, or you could try MacDroid.
I haven't tested MacDroid with a Doro specifically. I do use it regularly with Samsung and Oppo phones, though, and file transfers to my MacBook have been reliable. USB works well when my internet is unstable, while Wi-Fi is more convenient when the connection is solid. Both methods have been quick and trouble-free for me.
If you try it with your Doro, post an update. That would probably help anyone else here with the same setup.
Don’t expect the Doro to appear in Finder like a USB drive, especially if it’s an Android-based model. macOS does not handle Android’s MTP file-transfer mode on its own.
Before installing anything, unlock the phone after connecting it and check the USB notification. Change it from “Charging only” to “File transfer” or “MTP.” If that option never appears, try another cable since many USB cables carry power but no data. A different USB port or adapter can matter too.
@jackson’s MacDroid suggestion makes sense once MTP is enabled, but software cannot fix a charge-only cable or the wrong USB setting. For photos only, switching the phone to PTP may let the Mac’s Photos or Image Capture app see it. If your Doro has a removable microSD card, using a card reader is often the least frustrating workaround.
If your Doro is one of the basic non-Android models, MacDroid and other MTP apps may do nothing because the phone may not support Android file transfer at all. Check the exact model number first. Some Doro phones only expose a microSD card over USB, while their internal storage remains inaccessible to the Mac.
For an Android-based Doro, @bytegadget13 has the right troubleshooting order: confirm the cable carries data, unlock the phone, then select File transfer. MacDroid only becomes useful after that connection exists, so I would not install software until the USB menu appears.
For a basic model without workable USB transfer, Bluetooth can move a few photos to the Mac, though it is painfully slow for large batches. Setting the camera to save new photos directly to a microSD card and using a card reader is usually the cleaner route.
Don’t dismiss the “Allow access to phone data” prompt after selecting File transfer, or MacDroid may still show an empty device. You normally don’t need Mac drivers or USB debugging, just an unlocked phone, MTP mode, and that permission approved.
Don’t choose “Delete after import” the first time the Mac finally sees the phone. Copy a few photos, open them on the Mac, and confirm they transferred properly before removing anything from the Doro.
The main point is that there usually isn’t a Doro driver to install. On an Android-based Doro, the phone has to be unlocked before you connect it, and you may need to select “File transfer” every single time. That setting often falls back to charging after the cable is removed. Approve any data-access prompt too, as @samthecircuit mentioned.
I’d use this order:
  1. Connect the Doro directly to the Mac if possible, without a dock or hub.
  2. Unlock the phone and leave the screen on.
  3. Pull down the phone’s notifications and tap the USB message.
  4. Select “File transfer,” “MTP,” or “Transferring files.”
  5. If you only need camera photos, try “Photo transfer” or “PTP.”
  6. Open the transfer app on the Mac only after doing those steps.
MacDroid or Doro’s transfer software can handle MTP because Finder generally won’t. It still won’t repair a bad USB connection, though. If the phone keeps charging without displaying a USB notification, swap in a cable that you know has transferred data before. Some USB-C adapters and monitor ports are unreliable for this, so a direct port or a simple data-rated adapter is preferable.
Once connected, camera photos are normally under DCIM/Camera, while screenshots may be under Pictures/Screenshots. Downloads and files received through messaging apps can be scattered elsewhere, so an apparently empty photo folder does not necessarily mean the connection failed.
If it is a basic Doro rather than an Android model, stop chasing Mac drivers. The realistic options may be a microSD reader, Bluetooth for a handful of files, or sending the files through email or cloud storage. The exact Doro model matters more here than the version of macOS. AirDrop is not a direct option between a Doro and a Mac.
Copying ten photos is a very different case from dragging an entire 30 GB camera folder in one go. MTP transfer apps can be perfectly usable for small batches yet become slow, appear frozen, or lose the connection during a long transfer. That is not necessarily a Doro-specific fault. The phone is not mounted as a normal disk, so the Mac app has to request files through the phone’s MTP service.
For that reason, I would treat Doro’s Android File Transfer option as a basic copying tool rather than something dependable enough for backups or folder synchronization. Keep the Doro unlocked, prevent it from going to sleep during the copy, and start with a small group of files. Large video files and folders containing thousands of photos are more likely to expose connection problems.
The advice from @virtualarchitect4105 about verifying files before deleting them is especially important here. Use copy, not move. Open several transferred photos or videos on the Mac and compare the file count before removing anything from the phone. An interrupted MTP session can leave an incomplete file that still has a normal-looking name.
If the application hangs repeatedly, try transferring one folder at a time before changing software. A single damaged or oddly named file can sometimes be where the process stops. Relaunching the app and continuing with a smaller selection may tell you whether the problem is the whole connection or just that batch.
MacDroid may give you a nicer interface, but it still depends on the same underlying USB connection and MTP mode. It cannot make a marginal cable or unstable adapter reliable. For occasional photos, either application may be adequate. For frequent large transfers, a microSD card reader is usually faster and removes the phone, MTP session, and transfer app from the chain entirely.
The cloud and email fallback that keeps getting mentioned has a catch nobody flagged: a lot of those routes quietly shrink your photos. Email attachments get resized, and some cloud apps upload a compressed copy unless you dig into settings and force full resolution. If you only care about grabbing a few snaps to text to family, fine. If those are the only copies of anything you want to keep, that matters.
I think the thread is right that the model number decides almost everything here, and @megathread nailed the split. What I’d push back on slightly is the assumption that every Doro someone asks about is Android. A big chunk of Doro’s lineup is aimed at people who want simple phones, and plenty of those are the basic type where internal storage just never shows up over USB no matter what cable or app you throw at it. So before anyone spends an evening chasing MTP settings, flip the phone over or check the box for the model and search whether it even runs Android. Two minutes saved versus an hour of frustration.
On the MacDroid mentions, it makes sense as the piece that fills the gap Finder leaves, since macOS genuinely won’t mount an Android device on its own. But I’d treat it the way @0xbit1 described, as a copier for small stuff, not a backup tool. The underlying MTP connection is the weak link, and no app patches over a flaky cable or a hub that only passes power.
Honestly, if this is a photos-off-the-phone situation and the Doro takes a microSD card, I’d skip the whole USB dance. Pull the card, drop it in a reader, done. No unlocking, no permission prompt, no app that stalls halfway through a big folder. The card reader angle got a mention already but it kept landing as a last resort, and for anything past a handful of files I’d actually make it the first choice. Faster, cheaper than most people expect, and it takes the phone completely out of the equation.
For a few photos, try emailing them to yourself instead. If your Doro runs Android and already has Gmail set up, compose a message, tap the attachment icon, select your photos, and send it to your own address.
On your Mac, open the email and download the attachements into a folder. Start with two or three photos rather than your whole collection.
Check each downloaded photo beofre deleting anything from your Doro. I’d try this route for occasional transfers rather than spend time troubleshooting USB software.
