Anyone Know How To Recover Data From Corrupted USB Drive?
My USB drive suddenly stopped opening after I moved important work files and family photos onto it. Now my computer says the drive is corrupted and asks me to format it, but I need to recover the data before I lose everything. I’m looking for safe USB data recovery tips, software recommendations, or steps that might help.
Been there. A USB stick going unreadable feels bad fast when your own files are on it.
The part people miss is this. Corruption does not always mean the files are gone. A lot of the time, the storage is still holding the data, but the file system got messed up. I’ve seen it after yanking the drive without ejecting, losing power during a copy, random file system errors, malware, worn-out flash memory, and old drives doing old-drive stuff.
First thing I’d check
I’d split it into two buckets. File system trouble, or hardware trouble.
Recovery software is usually worth a shot if your USB does any of these:
  1. It shows up in Disk Management or Disk Utility.
  2. It pops up a format prompt.
  3. It shows as RAW, unreadable, or inaccessible.
  4. The storage size looks correct.
I’d stop and think about a recovery shop instead if you’re seeing this sort of behavior:
  1. The drive never appears at all.
  2. It keeps disconnecting and reconnecting.
  3. Your PC hangs or locks up when you plug it in.
  4. The connector or casing is damaged.
  5. The files matter enough where one bad move would hurt.
What not to do first
Don’t format it yet. Don’t run CHKDSK yet either. I learned this one the annoying way. Pull the files off first, try repairs after.
What I’d do for a DIY attempt
I’d start with Disk Drill. It has worked well for me on corrupted flash drives because it scans the device itself, instead of depending on a clean file system structure.
The usual flow looks like this:
  1. Install Disk Drill on your computer, not onto the damaged USB.
  2. Plug in the USB and open Disk Drill.
  3. Pick the USB from the list of devices.
  4. Hit Search for Lost Data.
  5. Let the scan finish. Don’t interrupt it unless the drive is acting weird.
  6. Preview what it finds.
  7. Recover everything to another drive, never back to the same USB.
If the drive feels shaky
If the stick drops out, stalls, or acts flaky, I would make a byte-for-byte backup first and scan the image file instead of hammering the original device. That puts less strain on a drive that might be close to done. I didnt do this once and the second scan went worse than the first. Learned my lesson there.
After the files are safe
Only after recovery, I’d try fixing the USB itself.
  1. Run CHKDSK if you’re on Windows.
  2. Run First Aid in Disk Utility if you’re on macOS.
  3. Reformat the drive if repair tools don’t clean it up.
  4. Test it with a big copy job, both writing to it and reading back from it.
When I’d throw the drive out
If corruption returns after formatting, writes fail, files vanish again, or diagnostics show errors, I’d replace the USB and move on. Flash drives are cheap. Losing the same files twice is not, and yeah, that part sucks.
Do not format it. That prompt is your enemy right now.
I agree with @mikeappsreviewer on skipping repairs first, but I’d add one thing. Try the easy connection checks before you scan. Different USB port. Different cable if it uses one. Different computer. I’ve seen drives show as corrupted on one Windows machine, then open enough on another system to copy files off. It sounds dumb, but it saves time.
If the drive still shows up with the right size, your best shot is recovery software. Disk Drill is a solid pick for corrupted USB data recovery because it reads the drive directly and often pulls files from damaged or RAW partitions. Preview the photos first. If previews work, recovery odds are usualy better.
A few practical tips:
  1. Stop using the USB now.
  2. Check Disk Management. If the capacity looks normal, scan it.
  3. Recover files to your PC or another external drive.
  4. Start with the most important folders, family photos, work docs, tax stuff, etc.
  5. If the scan finds thousands of files with weird names, use file type filters and dates.
One place I slightly disagree with @mikeappsreviewer. CHKDSK is not always a later option I’d bother with on flash drives. If the USB already turned flaky once, I recover what matters, then I replace the stick. They fail a lot, and they fail fast.
If you want a quick visual walkthrough, this quick guide to recover data from a corrupted USB drive covers the basic flow in a simple way.
If the USB disconnects mid-scan or makes the whole PC freeze, stop the DIY route. At taht point, a recovery lab is safer.
Don’t click Format. Also, I’d be a little careful with the “just scan it right away” advice from @mikeappsreviewer and @nachtdromer if the USB is acting unstable. If the drive is mounting, disappearing, then coming back, every extra read can make things worse on a dying flash stick.
What I’d do first is check SMART or at least basic device behavior with something like CrystalDiskInfo if it can read the controller at all. If not, look in Disk Management and note whether the partition is RAW, unallocated, or just missing a letter. That tells you a lot.
One thing people dont mention enough: if the files were just moved and not copied, check the original source too. Sometimes the move partially failed and some data is still there, in temp folders, recent files, cloud sync cache, etc.
If the USB shows normal capacity and stays connected, Disk Drill is a legit option for corrupted USB drive recovery. I’d recover by file type first, photos/docs, instead of chasing the old folder tree if the file system is trashed.
Also, skip “repair” tools from random websites. Most are junk.
If you want another reference point, here’s a useful Facebook discussion on USB flash drive data recovery tips.
Do one thing none of the others stressed enough: make an image of the USB first if the drive is still detectable. I slightly disagree with @nachtdromer and @sonhadordobosque on going straight into a full scan if the stick feels even a little unstable. A raw image gives you retries later without re-reading the failing flash over and over.
On Windows, use something like HDD Raw Copy Tool or USB Image Tool. Save the image to your internal drive, then run recovery against that image, not the USB itself.
Also check Event Viewer after plugging it in. If you see repeated disk, controller, or I/O errors, that points more toward hardware failure than simple file system corruption.
Disk Drill is fine here if the device stays online.
  • easy preview
  • good at RAW/corrupted partitions
  • can recover by file type when folders are wrecked
  • deep scans can take a while
  • recovered filenames/folder structure may be messy
  • not magic if the controller or NAND is dying
If it only works for a minute at a time, skip DIY and go to a lab before the drive fully quits.
